Nokia 1520 Microphone problems
2014-06-23T14:26:29+00:00
Hey,
I have a nokia lumia 1520 and Im having trouble making phone calls, people cant hear me talk, Only when I set it to handsfree people can hear me. Im pretty sure it has to do some with the noise cancelling, cancelling out my voice.
any software update to solve this issue?
    2014-06-25T08:16:47+00:00
    Im located in the netherlands
    2014-06-24T22:36:10+00:00
    Hi, Tims0l.
    Welcome to the Nokia Support Discussions.
    You may also consider recovering your phone's SW: Nokia Software Recovery Tool. Note that the link is intended for the US. Tell us your location so we can give you the correct link.
    2014-06-24T11:46:02+00:00
    all software is updated, not sure how the firmware is updated? do I need to do that manualy or is it included in the updates?
    soft reset doesnt solve the problem
    2014-06-24T11:44:23+00:00
    1. Check that your microphone is not muted. Also, restarting your phone could resolve the issue. To do that, hold the Power and Volume Down keys simultaneously until the phone vibrates. Release and the phone will restart.
    Microphone is not muted plus I restarted it multiple times and it doesnt help
    1. Check that the microphone opening is not blocked. To find the microphone opening, refer to your phone user guide.
    microphone is not blocked
    1. Move to a quieter area.
    doesnt help
    1. Set your phone to loudspeaker mode, or try a wired headset that has a microphone.
    this helps and then I am able to make phonecalls but I cant have a private phonecall plus I get a lot more background noise
    1. Check if the issue is with a specific number on outgoing or incoming calls.
    its with all the numbers doesnt matter if its incoming or outgoing
    1. Use the volume keys to adjust the volume.
    doesnt matter
    1. Test your phone's microphone and speakers with the pre-installed voice recorder. To record a clip, go to Messaging > New (+)Attach and tap voice note. Record an audio clip, and play the recording. If you can hear the recording, your microphone is ok.
    this works, it records audio messages fine
    2014-06-24T08:04:47+00:00
    You may also try to check the steps provided on this link to determine the real cause of your concern.
