Asus Vivotab RT: flash doesn't work!
2013-10-21T18:09:25+00:00
I have a problem with my LED flash.
4 days ago I've bought Asus Vivotab RT. I've run it, updated and installed some apps from a Store.
I also made a few photos in dark to try my LED diode and flash. Everything worked fine.
On Thursday Microsoft released an Windows 8.1 RT update. I couldn't wait for install it.
After the installation my OS works fine but the only problem was that I had to reinstall apps from Store because all my apps had been in Czech and changed language to English.
But yesterday I wanted to take a photo at night and there was no flash, my photo was dark. I tried different apps: from Microsoft  - Camera and original from Asus - Asus Camera. I've reinstall Asus Camera many times but when I press More options there is no Asus option for flash or diode and no special effects as sepia or contrast as it had been.
I've searched on Google for similar problems and the conclusion mostly was that Asus or Microsoft has to release an update. Those questions were half year old so I'm not sure how it is with updates now.
Has anyone same problems or experience with it? What shall I do?
Do I have to return my tablet and ask for a new one?
Thank's and respond please!
2013-12-31T14:27:06+00:00
I hope this helps..
(please note that u should be doing this from the asus vivo rt assuming the asus camera app is already installed)
1.  Go here:
http://support.asus.com/knowledge.aspx?SLanguage=en&p=28&m=ASUS%20VivoTab%20RT&hashedid=YLtKiymAzauHglcp
  1. Click on download then select the OS  => Windows RT
  2. Click on the plus sign next to Utilties
You will then see the part with description "Camera flash not working..."
  1. Go ahead and click on the first Global DLM
  2. It will download the the rar file to the tab
  3. extraxt the rar en then execute the camera.reg (just double click on it) and confirm when asked if you want to modify the registry etc..
  4. reboot the tab
  5. and then just wait..
after a while.. (it took me about 15 minutes) just start the asus camera app en open more options, you will notice the difference
2013-12-30T22:34:34+00:00
Good News! I just got another email from Asus about the flash.
Quote:  We have a fix for the camera flash slated to be released this week. So if you haven't updated yet, and was concerned due to the camera issue, we have sorted it out and the camera will now work 100% with Windows 8.1 on the VivoTab RT!
57 additional answers
    2013-12-19T22:01:32+00:00
    I just bought 2 Asus tf600t and after installing windows 8.1 rt both tablets lost their flashes. There is no more options also for the flash at all. How can Microsoft be so careless one has to wonder. I sure hope they come up with a fix because without the flash the camera is pretty much useless.
    Microsoft -20 for you...
    2013-12-23T13:53:07+00:00
    Has anyone updated with the latest 8.1 update that was a couple weeks ago and did it fix the camera flash? I bought one for Christmas and am thinking I should just send it back without even opening it.
    2013-12-23T22:45:37+00:00
    The 8.1 update is what took away the flash. Asus says Microsoft is working on a fix for this. Other than this problem, I have had no problems at all with the tablet and like it more than my Nexus 7. Windows 8.1 RT is more friendly than Android Kit Kat. I used the tablet without the flash to take pictures last night at a Christmas party with ordinary room lights and they all turned out well.  Hopefully, Microsoft will be issuing a fix for the flash soon, as I really like being able to transfer pictures and other files to my laptop thru the cloud, but I also want to be able to use the flash in low light.
