I hope this helps..
(please note that u should be doing this from the asus vivo rt assuming the asus camera app is already installed)
1. Go here:
- Click on download then select the OS => Windows RT
- Click on the plus sign next to Utilties
You will then see the part with description "Camera flash not working..."
- Go ahead and click on the first Global DLM
- It will download the the rar file to the tab
- extraxt the rar en then execute the camera.reg (just double click on it) and confirm when asked if you want to modify the registry etc..
- reboot the tab
- and then just wait..
after a while.. (it took me about 15 minutes) just start the asus camera app en open more options, you will notice the difference
