Two finger right click does not work
2013-10-18T16:17:22+00:00
I recently installed Windows 8.1 and the two finger right click gesture on my touchpad stopped working. Before the update it was working fine. I do not know how to fix it.
2014-01-21T14:44:09+00:00
Hey, I personally found this way for the 2 Finger-click to work out after searching for 4-5 months ( I am assuming your touchpad is Synaptics; as mine is) :
  1. To re-enable two finger tap, press Windows key + R, enter "regedit" then press enter, and on the left pane browse to the following location:
HKEY_CURRENT_USER\Software\Synaptics\SynTP\TouchPadPS2
  1. In the right pane, double click on 2FingerTapAction and change the value to a "2" (Hexadecimal) for right click, or a "4" (Hexadecimal) for middle click.
  2. Double click on 2FingerTapPluginID and clear any value it may have.
  3. In the right pane, find the MultiFingerTapFlags key and change it from a 2 to a 3.
  4. Additionally, if you want to enable three finger tap for middle click, double click on 3FingerTapAction and change the value to a "4", also clear any value for 3FingerTapPluginID and set 3FingerTapPluginActionID to "0".
  5. Restart your PC and you can see the changes well enough.
Note: You should be careful enough while changing the keys in the Registry, as any deletion or wrong entry may create problems in running Windows.
Good Luck!
2014-02-02T16:45:55+00:00
To the above 'Jeet Das's answer, I'd like to add that on my Lenovo IdeaPad Y500, the settings that needed to be changed were under
HKEY_CURRENT_USER\Software\Synaptics\SynTP\TouchPadSMB2c
Thanks Jeet!
49 additional answers
    2013-11-23T10:59:03+00:00
    This problem is not solved after reinstalling drivers.
    2013-11-23T10:57:00+00:00
    Same problem in my HP Pavilion 15-N019TUand i updated the driver of the touch pad and still
    there is problem in right click with two fingers.
    2013-11-22T10:56:38+00:00
    get the drivers from the acer page:
    http://www.acer.co.in/ac/en/IN/content/drivers
    everything workes fine now
