Processor maximum speed locked at 0.76 GHz
2014-05-27T00:04:11+00:00
EDIT: The problem seems to have been fully resolved by doing a clean install of Windows 10.
I use an AMD A6 processor on my Lenovo IdeaPad Flex 15D. Recently, my PC has been slow, and checking the Task Manager shows that the processor speed is only 0.76-0.78 GHz, while my processor's maximum speed is 2.00 GHz. The Resource Monitor says that my maximum frequency is 38-39% (0.76-0.78 GHz). This happens even when I'm in High Performance mode, and I've checked to make sure that the minimum and maximum speeds (in the power options) are set to 100%. I've also set the ATI Powerplay settings to Maximize Performance. The speed does not increase even when I'm running many programs at once.
Any help would be very appreciated.
I've noticed something interesting... The CPU speed in the Task Manager always seems to hang around 0.7-0.78 GHz, even when I'm not doing anything else on my laptop. Perhaps there's something that is not only preventing it from going above 0.78 GHz, but preventing it from going below 0.7 GHz. I have no idea why this is happening.
2014-05-27T00:22:00+00:00
You need to check with Lenovo Support, their on-line documentation and drivers, and
ask in their forums about any known issues.
Lenovo Support and downloads
http://www-307.ibm.com/pc/support/site.wss/homeLenovo.do
Lenovo Forums
http://forums.lenovo.com/Hope this helps.
Rob Brown - Microsoft MVP <- profile - Windows Expert - Consumer : Bicycle - Mark Twain said it right.
61 additional answers
    2014-06-04T20:34:16+00:00
    This really is a Lenovo issue probably related to their battery/power management. Check
    with Lenovo and Intel Support.
    Intel - Support - Community and Forums
    http://intelopenport.hosted.jivesoftware.com/community/tech
    You "might" get some assistance at Microsoft Support direct.
    Call Microsoft Customer Service direct - 1-800-642-7676 - hours 5 AM
    til 9 PM PST time (USA) - Saturday and Sunday, 6:00 AM – 3:00 PM
    PST time (USA). In Canada, call (877)568-2495.
    Contact Microsoft Customer Service
    http://support.microsoft.com/kb/295539
    Microsoft Support - Contact Us
    http://support.microsoft.com/contactus/?ws=support#tab0
    Microsoft - Phone Numbers for Microsoft Technical Support
    http://support.microsoft.com/kb/319726/en-us
    Microsoft - Contact Us by Email
    http://support.microsoft.com/contactus/cu_sc_selector_email?ws=support%2csupport
    Windows 8.1 Solution Center - there are options and a "Get live help"
    http://support.microsoft.com/find-solutions/windows/windows-8-1/
    Windows 8 Solution Center - there are options and a "Get live help"
    http://support.microsoft.com/gp/windows-8
    Microsoft Solution Centers - Select Product
    http://support.microsoft.com/select/?target=hub
    Hope this helps.
    Rob Brown - Microsoft MVP <- profile - Windows Expert - Consumer : Bicycle <- Mark Twain said it right!
    2014-06-04T20:17:00+00:00
    Here's what the Resource Monitor is showing now. It doesn't say any of the CPU are parked.
    2014-06-04T20:15:44+00:00
    Lenovo Power Management could be involved so also check with Lenovo Support
    and their forum.
    Rob - SpiritX
    2014-06-04T20:03:12+00:00
    I hadn't noticed that before, and after checking again, I only see that message show up for a few seconds every so often. Sometimes it says CPU 3 is parked also.
    As for battery control, etc... There's the default Lenovo Power Management, which also allows you to set power modes, but they directly correspond to the Windows power modes. I had Razer Game Booster for a while, but after I realized it wasn't helping, I uninstalled it. I have AMD Gaming Evolved, which is similar to Steam only it lets you set graphics specifications for your games before launching them.
    After encountering the problems, I installed MSI Afterburner, but it can't set a higher CPU speed than 0.78 GHz. I also got AMD Overdrive to try to solve the problems, but it says that my processor doesn't support it (which is what I was told by the second Lenovo tech that I spoke to).
    I'll look into those programs; thanks again for your help :)
    Owen
