How to remove $RECYCLE.BIN & System Volume Information from Each partition
2013-10-12T13:02:59+00:00
My windows 8.1 Pro (final release) infected with $RECYCLE.BIN & System Volume Information virus/malware in each partition.I have tried with windows Defender and Microsoft safety scannerto remove but windows Defender and Microsoft safety scanner not detect them.If i try to delete,it again appears.
Advice me how to remove " $RECYCLE.BIN & System Volume Information from each partition plea
<original title: How to remove $RECYCLE.BIN & System Volume Information virus from Each partition>
<moved from Virus and Malware>
2013-10-12T13:13:08+00:00
Typically $RECYCLE.BIN is for recycle bin allocation form your hard disk partition. and  System Volume Information bears the useful info regarding your volume.
These things are shown because hide protected system files tick is removed
Cant say it a virus effect or not..
If you feel like infected, much better to take the assistance of antivirus software
Download hitman pro 3.7**(shareware and can be activated for 30 days free)**and have a full system scan.. http://www.surfright.nl/en
And/or
use malwarebyte have a full system scan http://www.malwarebytes.org/products/malwarebytes_free/
After verifying , you can just make them invisible by doing this...
Note:- Optional/additional info -----(You DON'T have to run below to fix the problem )
Any folder and its content can be made shown as a recycle bin using a desktop.ini
Normally within this desktop.ini u can see.
[.ShellClassInfo]
CLSID={645FF040-5081-101B-9F08-00AA002F954E}
LocalizedResourceName=@%SystemRoot%\system32\shell32.dll,-8964
open a command prompt run as administrator
https://technet.microsoft.com/en-us/library/cc947813%28v=ws.10%29.aspx?f=255&MSPPError=-2147217396
change the the folder attrattributesre desktop.ini is kept using
attrib +a +s +h +r "folder" \* /d /s
you will see a recyclear bin folder
45 additional answers
    2015-06-15T15:02:32+00:00
    same problem i got they are not deleting p
    2015-06-08T10:48:27+00:00
    Hi mr Hetti,
    I am still waiting for your reply
    pls help me out
    cheers
    Deepan
    Open a command prompt run as admin..
    Then type
    d:
    hit enter button in the keyboard and type
    cd D:\Movies
    then you should see your commad prompt has changed to
    D:\Movies**>**
    Now use attrib command in the following manner
    **In a nutshell you should see your path has changed in command promptD:\Movies>**before hitting enter
    D:\Movies**>*attrib -a -r -s -h /d /s \
    hit enter.. (Do not blindly hit enter with attrib command make sure your command prompt path has changed to D:\Movies)
    This will remove unnecessary hide/system attributes/options from your movies ..
    Then you should go ahead with the hiding default hidden items..
    2015-06-08T09:49:31+00:00
    Hi mr Hetti,
    pls help me out
    cheers
    Deepan
    2015-06-06T17:47:12+00:00
    Hi Hetti,
    D:\Movies"name of movies".mkv
    My movie file paths like this.
    when i tried to move them then it shows:-
    The file properties are as follows:-
    i make them read only otherwise they are really hidden and i can't see them.
    Pls help me out...
    waiting for your reply.
    cheers
    Deepan
