How to remove $RECYCLE.BIN & System Volume Information from Each partition
2013-10-12T13:02:59+00:00
My windows 8.1 Pro (final release) infected with $RECYCLE.BIN & System Volume Information virus/malware in each partition.I have tried with windows Defender and Microsoft safety scannerto remove but windows Defender and Microsoft safety scanner not detect them.If i try to delete,it again appears.
Advice me how to remove " $RECYCLE.BIN & System Volume Information from each partition plea
<original title: How to remove $RECYCLE.BIN & System Volume Information virus from Each partition>
<moved from Virus and Malware>
2013-10-12T13:13:08+00:00
Typically $RECYCLE.BIN is for recycle bin allocation form your hard disk partition. and  System Volume Information bears the useful info regarding your volume.
These things are shown because hide protected system files tick is removed
Cant say it a virus effect or not..
If you feel like infected, much better to take the assistance of antivirus software
Download hitman pro 3.7**(shareware and can be activated for 30 days free)**and have a full system scan.. http://www.surfright.nl/en
And/or
use malwarebyte have a full system scan http://www.malwarebytes.org/products/malwarebytes_free/
After verifying , you can just make them invisible by doing this...
Note:- Optional/additional info -----(You DON'T have to run below to fix the problem )
Any folder and its content can be made shown as a recycle bin using a desktop.ini
Normally within this desktop.ini u can see.
[.ShellClassInfo]
CLSID={645FF040-5081-101B-9F08-00AA002F954E}
LocalizedResourceName=@%SystemRoot%\system32\shell32.dll,-8964
open a command prompt run as administrator
https://technet.microsoft.com/en-us/library/cc947813%28v=ws.10%29.aspx?f=255&MSPPError=-2147217396
change the the folder attrattributesre desktop.ini is kept using
attrib +a +s +h +r "folder" \* /d /s
you will see a recyclear bin folder
45 additional answers
    2015-05-30T19:31:03+00:00
    Thanks!!! :-)
    2015-05-30T10:07:37+00:00
    Thanks admin it's really helpfull.
    2015-02-08T04:23:19+00:00
    Thank you Very Much sir.
    2015-02-01T19:17:30+00:00
    I have been trying to get rid of $Recycle.bin and System Volume Information from a couple of external and main hdd. No success.. I`m quite sure they are some kind of malware and hiding them will not do for me.
