I ordered a pcb mic for replacement, hope will work,keep everyone in touch.
Nokia Lumia 930 microphone problem
Hello.
I got an issue with my Lumia 930 that i bought today.
When i've got an incomming/outgoing call the person on the other end can't hear me, but i can hear them clearly. It works when i put the call on speaker, but i want to be able to call someone and not sharing the conversation with everyone around me.
So far i've done:
Soft reset
Hard reset
Nokia Software recovery tool
Does anyone have this issue?
Is there a fix for this or should i return it?
2015-12-20T11:48:45+00:00 -
2015-12-20T10:54:04+00:00 I have tweeted him many times. I think we need to run a campaign to raise our voice. If anyone has good idea for this..tell me. I will join.
2015-12-15T16:54:57+00:00 It's not a software, I asked MS via Gabe Aul, and Customer Service to publish a fix via update, to reasign the mic that are working (we have 4 in total, less 1 not working) but no luck, neither answer from them... The idea now is to buy a mic on ebay and try to replace it by myself, but don't know if it's going to work...
2015-12-15T14:15:10+00:00 What software did you use to try that? I'd like to give that a go myself. I can't send it off for repair as I can't afford to be without my phone for 5 or weeks.
2015-12-14T13:27:56+00:00 Hi, tried many things, including asking MS to reasign mics via software to use only no faulty mics, but no luck.
I live in Argentina and no Nokia Service for 930 here, I have been thinking on buying a mic and replacing it by myself, there are videos in YouTube on opening the phone.. anybody did this?
