"My removable device" shortcut virus..
2013-02-25T20:21:23+00:00
When I plug my USB on my computer, a virus hides my files and creates a shortcut called "My removable device".
If I check shortcut's properties it shows this path "C:\windows\system32\rundll32.exe ~$WV.FAT32,_ldr@16 desktop.ini RET TLS " ".
I ran AVG Antivirus and it found the following:
Trojan horse Deflier.G
Windows/SysWOW64/svchost.exe
and it deleted it.
I format my usb, then I re-insert the USB and the shortcut is there.. again.
If I run a "show usb" program, it shows me the hidden files, there are
desktop.ini
thumbs.db
autorun,ini
~$WOSFVR.FAT32
a folder with no name where all my files were relocated by the virus
and the evil shortcut.
please help.
[Moved from Windows]
Windows for home | Previous Windows versions | Security and privacy
2013-02-26T11:24:04+00:00
Hi Carlos,
Welcome to Microsoft Community and thanks for posting the question.
Based on the description provided, it looks like you are facing an issue while connecting USB to the computer.
It would be great if you could answer these questions in order to assist you further.
1.       Is the issue confined while connecting any particular USB?
2.       Have you made any changes to the computer prior to this issue?
I would suggest you to try the following methods and check.
Method 1:
I would suggest you to run the Microsoft Safety Scanner and check if there is any virus.
Microsoft Safety Scanner:  http://www.microsoft.com/security/scanner/en-us/default.aspx
Note: The Microsoft Safety Scanner expires 10 days after being downloaded. To rerun a scan with the latest anti-malware definitions, download and run the Microsoft Safety Scanner again. Any data files that are infected may be cleaned by deleting the file entirely, which means there is a potential for data loss.
 Method 2:
I would suggest you to Remove and reinstall all USB controllers.
To remove and reinstall all USB controllers, follow these steps:
a)    Click Start, click Run, type sysdm.cpl in the Open box, and then click OK.
b)    Click the Hardware tab.
c)     Click the Device Manager button.
d)    Expand Universal Serial Bus controllers.
e)    Right-click every device under the Universal Serial Bus controllers node, and then click Uninstall to remove them one at a time.
f)     Restart the computer, and then reinstall the USB controllers.
g)    Plug in the removable USB storage device, and then test to make sure that the issue is resolved.
Keep us posted on the status of the issue.
If you need any other information about Windows, feel free to post your questions and we will be glad to help.
66 additional answers
    2016-12-30T15:07:35+00:00
    Hey guys,I found a solution that has worked with all the users i have worked with:
    HERE IT IS
    First Download <program of unknown safety and effectiveness removed>
    Now open it.(It will open in the background in some cases but click its icon in the Notifications Area and it will open)
    Under USB Protection,in protection status,click on USB Scan and delete the THREATS.
    Now,go to Disk Management(In Windows 7,Click Start Menu,Search for Create and Format disk Partitions.And it will open)
    Now format the Removable Drive YOU HAVE INSERTED.It will take a long time.Please be Patient.
    DONE!!!
    YOUR WORK IS DONE. Virus (Not SO) Cleared.
    Now,Trust me its just a virus that will infect your Removable Drive but not the PC.
    2016-05-13T15:34:24+00:00
    Probably you should try finding anything that is consuming a lot of ram in the task manager... When I say a lot is really a lot! Between 2000 and 5000 bytes when nothing is opened. I you find anything, simply erase it or change its permissions.
