USB-IF xHCI USB host controller driver problem
2013-01-03T05:58:56+00:00
My new Windows 8 in Sony VAIO has detected problem with the driver for USB-IF xHCI USB host controller, which Windows couldn't reinstall. What to do? I haven't made the recovery disks yet! Please reply...
2013-01-06T16:12:49+00:00
I saw this post today and the information provided helped me fix this issue.
Click Here
http://www.eightforums.com/hardware-drivers/17161-intel-wiusb-driver-not-working-properly.html
The link basically says to visit the Intel website and use the Intel Driver Update Utility. The utility will automatically scan your computer for devices that are eligible for an update. Hope this helps you because it helped me. I also updated my Wireless driver while I was using the Intel Driver Update Utility since a newer driver was recently made available.
This worked for me; however, I ended up having to uninstall the old Intel WiDi driver and then restarting my computer before the setup.exe file would run and install on my computer (dell inspiron). I did create a restore point in case it didn't work, but everything seems to be running smoothly!
I should also point out that just deleting the Intel WiDi driver also got rid of the yellow exclamation mark, and unless you are planning to try and connect to your computer to your TV wirelessly, I don't think it is something that you need. Here is a link that explains what the driver does:
93 additional answers
    2013-08-10T23:04:26+00:00
    Terrible, Also I have various problems with usb etc. I think because of the Display Adapter`s Chipset, and everything what lies underneath, I mean usb controllers, serial bus controllers, mouse etc.. Even my Driver Scanners ! see what is wrong with my drivers, but after downloading ,I get the message now installing , but at the end nothing was installed, so somewhere Something is holding everything up.   I hope Microsoft Netherlands understands my explaining this problem.
    As soon as I`ve heard from them I contact you. Ronald The Netherlands
    2013-08-10T09:45:36+00:00
    Terrible, Also I have various problems with usb etc. I think because of the Chipset, and everything what lies underneath, I mean usb controllers, serial bus controllers, mouse etc.. Even my Driver Scanners see what is wrong with my drivers, but yes they are downloading the drivers , then i get the message now installing , but at the end nothing was installed, so somewhere Something is holding everything up.   I hope Microsoft Netherlands understands my explaining this problem.
    2013-08-10T09:45:05+00:00
    2013-08-07T12:06:43+00:00
    I have the same problem with my Lenovo ideapad u410. I can't print from any of my printers (wireless and USB connected) and when I check with device manager, there is a error 31 with the usb-if xhci host controller driver. Apparently, this driver was made in 2012, so I suppose changing the date to sometime in 2012 would work, but I don't wanna screw up the time for that. Lenovo says they are trying to make an update. As for the new USB controller on Intel, it's only compatible to Windows 7 and other types. Intel hasn't made one for Windows 8 yet, so all we have to do is wait for that update, or change the date. On Lenovo, there are many Windows 8 people with this problem, so hopefully this problem will be addressed to soon.
