How do I fix "Error Loading Player: No playable sources found
2013-01-30T21:29:29+00:00
I am using IE9 version  9.0.8112.16421
Update Version 9.0.12
2013-01-31T13:50:47+00:00
Hi Nate,
Thank you for choosing Windows and thanks for providing us an opportunity to assist you.
As per the description, you are having issues with an error message Error Loading Player: No playable sources found.
  1. When do you get this error message?
  2. Which Media Player are you using?
  3. What is the format of the file that you are trying to play?
Reply to us if you face any issues with Error loading Player message  or any other Windows Issue, and we would be glad to assist you.
Have a nice day!
8000+ people found this answer helpful.
79 additional answers
    2016-07-29T03:42:44+00:00
    Hey! i do work in try it >>> https://youtu.be/UQl1HNGc14U
    2016-08-10T17:38:18+00:00
    whenever i open the ozee application to play a video
    it says 'ERORR LOADIING PLAYER,NO PLAYABLE SOURCES FOUND'
    2016-08-18T12:17:26+00:00
    I know it's three years later, but if anyone is looking for a cure please ensure that the latest Flash Player is installed (from the Adobe site!) and is running.
    It worked for me with online TV stations and the BBC webiste, and I hope it may help someone else.
    If so, please post 'Installing Flash Player worked for me' here.
    Thank you.
    2016-09-16T22:27:07+00:00
    All I get is an endless circle that gives me NO ANSWER!    FIX YOUR DAMN SITE!!!!
