How do I fix "Error Loading Player: No playable sources found
2013-01-30T21:29:29+00:00
I am using IE9 version  9.0.8112.16421
Update Version 9.0.12
2013-01-31T13:50:47+00:00
Hi Nate,
Thank you for choosing Windows and thanks for providing us an opportunity to assist you.
As per the description, you are having issues with an error message Error Loading Player: No playable sources found.
  1. When do you get this error message?
  2. Which Media Player are you using?
  3. What is the format of the file that you are trying to play?
Reply to us if you face any issues with Error loading Player message  or any other Windows Issue, and we would be glad to assist you.
Have a nice day!
8000+ people found this answer helpful.
79 additional answers
    2017-04-21T16:27:30+00:00
    = On 22nd April,at 12:27 am.
    1. Which Media Player are you using?
    = <removed link>
    1. What is the format of the file that you are trying to play?
     = It says 'VIP 1'
    2017-05-01T11:54:38+00:00
    I have same problem trying to play http://www.abc.net.au/radio/melbourne/programs/sundays/sundays/8466022
    can you help. I am on Windows 10
    YAY!! I fixed it and here's how
    how fixed ABC Radio online not playing
    In Chrome click the three dots icon for menu and select Settings
    Show advanced settings
    Privacy - Content Settings
    Cookies - all cookies and site data - Clear all cookies
    Then in Content Settings scroll down to
    FLASH and select “Allow sites to run Flash”
    2017-05-01T16:12:16+00:00
    1. when i try to stream any video online.
    2. VLC Media Player.
    3. Movie 1080
    2017-05-11T20:08:08+00:00
    I am having the  same problem with trying to watch movies on hdonline also was working yesterday. Please help me fix it.  Error Loading Player: No playable sources found.
    Thank you
