Magic Jack error 3002 How do I fix this problem?
2013-03-08T03:59:08+00:00
I plugged in my new Magic Jack plus into my modem and I started getting this message repeated over and over. ERROR 3002.  Magic Jack said it was a problem with my ISP accepting multiple devices. Can anyone help me with this problem?
2013-03-08T22:34:09+00:00
Hi Robert,
Welcome to Microsoft Community and thanks for posting the question.
As per the description, you get an error code 3002 with Magic Jack.
The issue can be resolved by Rebooting  the Router.
Check the link mentioned below and see if it helps.
**http://www.magicjacksupport.com/a-sulution-for-error-3002-t11548.html**
Hope this information helps.
Reply to us if you face any other Windows Issue, and we would be glad to assist you.
Have a nice day!
2015-05-01T18:42:29+00:00
I have a Q1000 (esetially an Actiontec C1000 with Qwest branding) with the same issue. I reported it as a bug to magicjack. I got mine working with a second dhcp server. I limited the dhcp scope on my Q1000 to 192.168.0.10-192.168.0.20 and have a linux server plugged into the Q1000 on my linux box I have a dhcp server that I added the dhcp scope of 192.168.0.200 - 192.168.0.220 as soon as I activated the scope my magicjack was working.
54 additional answers
    2015-12-02T04:02:46+00:00
    Yes, I agree. I got this message when i disconnected my router and started using a router/ modem combo. I fixed the problem by disabling my firewall all the way. Then once I got a dial tone then I reactivated the router. It has something to do with the firewall settings. Hope this helps someone else.
    2015-09-15T06:00:10+00:00
    Rebooting the router did absolutely nothing! My router works fine!
    2015-09-15T05:48:01+00:00
    Absolutely, positively, it is not my router. it works with anything else. It's the MJ device itself. I had magicjack plus, and they sent me MAGICJACKGO!! I've lost phone/wifi service. I'm VERY upset! Now I'm supposed to wait another week for another magicjack device?! 3002 was the code by the way...
