HELP! I've encountered the SrtTrail.txt problem!!!
2013-02-19T09:56:54+00:00
My laptop with Windows 8 Pro 64-bit won't start properly. Every time that I start the laptop up, it tells me that I have a problem and it needs to restart. It then tries to auto-repair the system. I have BitLocker installed on my machine, encrypting my C:, so it asks for the recovery key. When I enter the recovery key it tries to diagnose my PC. After about a minute, I get told that auto-repair couldn't repair my PC, and the file which is causing the problem is C:\Windows\System32\Logfiles\Srt\SrtTrail.txt. I've tried all of the advanced options but they don't seem to be working as after using them it loops. Has anyone got any ideas on how to sort this problem out? The laptop I'm using is a SONY Vaio Duo 11 Ultrabook and I've had i for around 2/3 months.
Windows for home | Other | Search, touch, and mouse
2015-03-31T06:58:09+00:00
I followed the steps to enter the command in the command prompt. When I do I get the following message:
The drive, the path, or the file name is not valid.
I entered the following in the command prompt:
Chkdsk/f/r X:C
any further ideas?
Actually the command is chkdsk /f /r C:      not X:C
2016-08-15T16:39:43+00:00
Root cause found:
Unknown Bugcheck: Bugcheck 3b. Parameters = 0xc0000005, 0xfffff8018302da72, 0xffffd000cb3c8500, 0x0.
https://msdn.microsoft.com/en-us/library/windows/hardware/ff558949%28v=vs.85%29.aspx?f=255&MSPPError=-2147217396
(BING search for
    Bugcheck 3b
<quote>
may occur due to user-mode graphics drivers crossing over and passing bad data to the kernel code.
</quote>
If you can get into the Advanced boot options, try using the Low-res video option.   BTW it helps to have a boot menu to facilitate that.  Otherwise using bootable recovery media may be necessary.
Good luck
Robert Aldwinckle
600+ people found this answer helpful.
112 additional answers
    2013-02-22T08:50:17+00:00
    I have the same problem. And I don't have recovery CD. Also I used all of the advanced options. I did check disk through promt. Not helping too. How can I send you the content of srttrail.txt? Thank you
    2015-03-25T21:17:05+00:00
    i did this and it did work, is there anything else i should look after this works? i am concerned that it will happen again or that it will do something worse in the future. any-who, i was getting the error C000003A updating # of #. it would not work at all. after that i tried to restart the computer and it would try to do the automatic repair and would give me the blue screen that it could not be repaired to check file C:\windows\system32\Logfiles\Srt\srtTrail.txt
    i did press f7 to disable driver signature enforcer and it seemed to work. But my question goes back to the beginning. Do i need to do anything else after this worked? should i check a specific file? delete it?
    2013-05-09T22:31:46+00:00
    well i read your comment Rajesh Govind and still nothing happened it still wouldnt work and i will show you the SrtTrail.txt file which is below
    Startup Repair diagnosis and repair log
    Last successful boot time: ‎1/‎1/‎2012 12:09:05 AM (GMT)
    Number of repair attempts: 1
    Session details
    System Disk = \Device\Harddisk0
    Windows directory = C:\windows
    AutoChk Run = 0
    Number of root causes = 0
    Test Performed:
    Name: Check for updates
    Result: Completed successfully. Error code =  0x0
    Time taken = 15 ms
    Test Performed:
    Name: System disk test
    Time taken = 0 ms
    Test Performed:
    Name: Disk failure diagnosis
    Time taken = 328 ms
    Test Performed:
    Name: Disk metadata test
    Time taken = 31 ms
    Test Performed:
    Name: Target OS test
    Time taken = 234 ms
    Test Performed:
    Name: Volume content check
    Time taken = 655 ms
    Test Performed:
    Name: Boot manager diagnosis
    Time taken = 0 ms
    Test Performed:
    Name: System boot log diagnosis
    Time taken = 0 ms
    Test Performed:
    Name: Event log diagnosis
    Time taken = 203 ms
    Test Performed:
    Name: Internal state check
    Time taken = 0 ms
    Test Performed:
    Name: Boot status test
    Time taken = 31 ms
    Test Performed:
    Name: Setup state check
    Time taken = 640 ms
    Test Performed:
    Name: Registry hives test
    Time taken = 4087 ms
    Test Performed:
    Name: Windows boot log diagnosis
    Time taken = 0 ms
    Test Performed:
    Time taken = 1310 ms
    Test Performed:
    Name: Access control test
    Result: Started but not completed
    but i was wondering if you can actualy just delete the
    User , Program files, Program files x86 and Windows
    and just open things from Windows.old and just do that
    use your windows 7 again would that work?
    and im trying to fix it from my laptop sooooo the olny way i can move my files is by flash drive and disc. :( i acidently lost my recovery CD and i dont think ill bcan help mee able to find it so i hope you
