To anyone still having a problem with this error. You need to go to the repair console using the windows disk or built in console. Select troubleshoot, advanced options, startup settings and then restart. Once restarted you
will see a list of options. Select the option that refers to "disable driver signature enforcement". Restart the computer and the windows OS will load as normal. Once at your desktop navigate to the folder that was given when you couldn't boot into OS (e.g
“C:\Windows\System32\Logfiles\Srt\SrtTrail.txt”) and delete that text file. Restart computer, Problem sorted. I had the same problem and done this on other computers i have repaired and this solved the issues.
When I restart, it just starts the automatic repair all over again... No screen to press any numbers or anything please help.
Also, it leads me back to the screen where automatic repair couldn't repair my computer...
