Hi
Im still getting the same problems, have attached a copy of the SRT file......HELP Plzzzz What can I do, as I dont want to lose any data. Appreciate any assitance
Startup Repair diagnosis and repair log
Last successful boot time: 2/21/2016 3:23:36 PM (GMT)
Number of repair attempts: 60
Session details
System Disk = \Device\Harddisk0
Windows directory = E:\WINDOWS
AutoChk Run = 0
Number of root causes = 1
Test Performed:
Name: Check for updates
Result: Completed successfully. Error code = 0x0
Time taken = 0 ms
Test Performed:
Name: System disk test
Time taken = 0 ms
Test Performed:
Name: Disk failure diagnosis
Time taken = 390 ms
Test Performed:
Name: Disk metadata test
Time taken = 32 ms
Test Performed:
Name: Target OS test
Time taken = 31 ms
Test Performed:
Name: Volume content check
Time taken = 31 ms
Test Performed:
Name: Boot manager diagnosis
Time taken = 78 ms
Test Performed:
Name: System boot log diagnosis
Time taken = 0 ms
Test Performed:
Name: Event log diagnosis
Time taken = 375 ms
Test Performed:
Name: Internal state check
Time taken = 0 ms
Test Performed:
Name: Boot status test
Time taken = 32 ms
Test Performed:
Name: Setup state check
Time taken = 796 ms
Test Performed:
Name: Registry hives test
Time taken = 9063 ms
Test Performed:
Name: Windows boot log diagnosis
Time taken = 0 ms
Root cause found:
Boot critical file e:\windows\system32\drivers\windowstrustedrt.sys is corrupt.
Repair action: File repair
Result: Failed. Error code = 0x490
Time taken = 16171 ms
Repair action: System files integrity check and repair
Result: Failed. Error code = 0x57
Time taken = 1381547 ms
Session details
AutoChk Run = 0
Test Performed:
Time taken = 0 ms
Test Performed:
Time taken = 0 ms
Test Performed:
Time taken = 390 ms
Test Performed:
Time taken = 47 ms
Test Performed:
Time taken = 31 ms
Test Performed:
Time taken = 485 ms
Test Performed:
Time taken = 0 ms
Test Performed:
Time taken = 15 ms
Test Performed:
Time taken = 672 ms
Test Performed:
Time taken = 63 ms
Root cause found:
Startup Repair has tried several times but still cannot determine the cause of the problem.
Session details
AutoChk Run = 0
Test Performed:
Time taken = 0 ms
Test Performed:
Time taken = 0 ms
Test Performed:
Time taken = 406 ms
Test Performed:
Time taken = 47 ms
Test Performed:
Time taken = 31 ms
Test Performed:
Time taken = 469 ms
Test Performed:
Time taken = 0 ms
Test Performed:
Time taken = 0 ms
Test Performed:
Time taken = 641 ms
Test Performed:
Time taken = 62 ms
Root cause found:
