Hi, my family uses an envy 23 and I encountered the SrtTrail problem while switching it on today. I had inserted a cd-r into it at the start of this month for a project and selected use as a hard drive when formatting. I suspect that has something to do
with this problem. When I switch it on, it shows a blue screen that says automatic repair and below: automatic repair couldn't repair your PC n allows me to go advanced options. if I press it, it will give me 4 options: continue (exit n continue to Windows
8.1), use a device (use a USB drive, network connection, or Windows recovery DVD), troubleshoot (refresh or reset your PC, or use advanced tools) and turn off your pc. continue puts me in a loop with the pc showing the abv n turn off your pc does not solve
the prob as switching it on again puts me in that same loop. use a device gives me a list of devices and a option to see more devices, but clicking on any device will just put me in the same loop as if I had pressed continue. for troubleshoot, refresh doesn't
work as they say there was a problem refreshing your pc, No changes were made. Reset your PC is not being considered at the moment as my mum does not want to lose the important stuff she has on the PC. So advanced options is left. There is system restore (use
a restore point recorded on your PC to restore Windows), system image recover (recover windows using a specific system image file), startup repair (fix problems that keep windows from loading), command prompt (use the command prompt for advanced troubleshooting,
UEFI firmware settings (change settings in your PC's UEFI settings in your PC's UEFI firmware) and startup settings (change windows startup behaviour). all except command prompt I m either not sure about or unable to do. the commands do not work for command
prompt as I cant access the folder (srt.srttrail or something liddat). is there anyway to fix this prob without resetting the pc? please reply me ASAP. thank you.
