How to disable or remove hotkey F1 for Help and support?
2013-02-08T10:55:45+00:00
Hello dear Microsoft team!
 I would like to know, how can I disable hotkey feature (f1) or what file to delete to remove the hotkey feature (opens help and support programm) on my laptop. I am looking foward to hearing from you as soon as possible.
2016-07-30T06:46:53+00:00
For future users coming in off Google, don't listen to these non-helpful responses above.  This is how you do it: for Windows 10 (you can do any one of the three, you do not have to do all of them):
  1. Navigate to C:\Windows, find helppane.exe, right click, Properties, Security tab, Advanced.  On the top where it says "Owner:", hit change.  Type in your username and hit Check Names, click OK.  Apply.  Hit okay back to the Security tab.  Next to "to change permissions, click edit"  hit Edit.  Hit Add, type in your username and click Check Names.  Hit okay and then on the permissions give yourself Full Control with all boxes checked.  Click Apply, yes, then OK.  Ok again to close the box.  Then right click, rename it, hit enter and click Continue to provide administrator permission. to rename it.  Or simply click the file and press Delete on your keyboard to get rid of it.  Now you can press F1 without having to be bothered by the help pane popup!
  2. Open up command prompt, File, run new task, type in regedit and hit enter.  Click yes if there is a popup.
Please backup your registry before making any changes by clicking File > Export (make sure All is selected under Export Range).  Make sure to scroll up and select the uppermost level before searching, for me it is "Computer".  Then Edit > Find.  Under Find What: helppane.exe and make sure only Data is selected and nothing else.  This should lead you to the keys that point towards the executable which you can then rename or remove at your own risk.
  1. Use a program like Sharpkeys (search it online) to disable the F1 button (not recommended as it will disable the button entirely).
1500+ people found this answer helpful.
42 additional answers
    2013-02-09T11:35:44+00:00
    Anywhere when I click F1 (in game, working anywhere) that window opens, and I need other hotkeys to work while in-game, so I want to remove that (anyways not using that) Or to disable those hotkey for it.
    1000+ people found this answer helpful.
    2013-09-21T21:07:54+00:00
    Same Here any game I play, (while raiding... Annoying) if I press F1 by accident...POOF... Hello windows help and support... need to disable it
    2013-02-10T12:59:14+00:00
    so is there any solution to disable it? Please help
    2013-02-08T11:55:10+00:00
    Its a universal feature available within win and most third party programs, and as such I dont believe it can be disabled.
    Perhaps you would care to explain why you wish to do so.
