2013-01-06T19:59:33+00:00
2014-08-26T17:51:47+00:00
There, done.
2013-04-13T14:32:18+00:00
2014-10-25T21:52:00+00:00
2014-09-16T17:02:10+00:00
95 additional answers
    2015-06-15T14:35:01+00:00
    Done that but even though the option to TAP is off the pad by itself tapping becomes active. Tried the Geek squad many times on line and in person they relaod drives etc but the Dell xps12 touch pad frequently re actives itself but the option is still turned off?????
