2013-01-06T19:59:33+00:00
2014-08-26T17:51:47+00:00
There, done.
2013-04-13T14:32:18+00:00
2014-10-25T21:52:00+00:00
2014-09-16T17:02:10+00:00
95 additional answers
    2014-11-18T18:39:07+00:00
    I've done this, saved it, went back and checked it and the setting was properly saved, and for some reason, I can still click on things using the touch pad. This is extremely inconvenient, as often when I'm browsing my finger is hovering over the touch pad and if it happens to touch it, I click on something I don't want to, sometimes loosing hours of typing. I have no idea what else to do, if anyone has any suggestions, I'm all ears.
