2013-01-06T19:59:33+00:00
2014-08-26T17:51:47+00:00
There, done.
2013-04-13T14:32:18+00:00
2014-10-25T21:52:00+00:00
2014-09-16T17:02:10+00:00
95 additional answers
    2013-01-09T20:53:38+00:00
    Thanks but there is no touch pad listed in device settings / mouse. Also i have learned that windows 8 has disabled my buttons that were hard wired onto my keyboard of this laptop, an ASUS. The button for performance, visuals, and trackpad enable and disable. So windows 8 shouldnt have even had this affect on my custom buttons. :\
