2013-01-06T19:59:33+00:00
2014-08-26T17:51:47+00:00
There, done.
2013-04-13T14:32:18+00:00
2014-10-25T21:52:00+00:00
2014-09-16T17:02:10+00:00
95 additional answers
    2014-07-10T22:42:29+00:00
    Thank you so much for this, I too am running Windows 8 on an Asus. I use a mouse because of the reasons so many state. I did have the click pad turned off if an external mouse is being used, but a default must have occurred.  So I has to look and find where to turn off the click pad again.
    It was as you said, lower right arrow (show hidden icons) clicked on the box that was grey as you said, this opened the a window to adjust the click pad settings and the last option was to turn off the click pad totally while a mouse was detected.
