2013-01-06T19:59:33+00:00
2014-08-26T17:51:47+00:00
There, done.
2013-04-13T14:32:18+00:00
2014-10-25T21:52:00+00:00
2014-09-16T17:02:10+00:00
95 additional answers
    2014-01-24T02:02:53+00:00
    You can search all of Microsoft and find none as wise as you. So terrible that anything simple has to be so impossibly hid. You are the only person that found this hidden gem of a button to click on. No where in help, hints, or hidden volumes does this information reside. If we could just get windows 8 to stop popping up that tablet looking screen and stay on the desk top now that would be the holy grail of the Microsoft world. Maybe get a start button and control panel back and it just might be a half way usable software again. But I do thank you for this small step on the pathway. I can type again and not have my screen zooming between 25% and 400% as I try to scroll.
