2013-01-06T19:59:33+00:00
2014-08-26T17:51:47+00:00
There, done.
2013-04-13T14:32:18+00:00
2014-10-25T21:52:00+00:00
2014-09-16T17:02:10+00:00
95 additional answers
    2013-01-08T00:56:49+00:00
    i use a USB mouse.
    Why not disable the Touchpad completely then?  If you don't see a more convenient way of doing it you could use Device Manager to simply disable it.   Otherwise, give some details about your hardware.   E.g. some can be disabled temporarily by a hardware switch or keyboard shortcut but this is really a question your computer manufacturer would be better able to deal with and not really a Windows issue.
    HTH
    Robert  Aldwinckle
