2013-01-06T19:59:33+00:00
2014-08-26T17:51:47+00:00
There, done.
2013-04-13T14:32:18+00:00
2014-10-25T21:52:00+00:00
2014-09-16T17:02:10+00:00
95 additional answers
    2013-10-16T21:23:53+00:00
    I also had this same problem with the stupid tap-clicking. None of these solutions worked for me, because I couldn't find "Synaptics" and my Mouse properties didn't give me any options to adjust the clicking. I found it using the method in this video
    http://www.youtube.com/watch?v=k0PWQbRV9WA
