2013-01-06T19:59:33+00:00
2014-08-26T17:51:47+00:00
There, done.
2013-04-13T14:32:18+00:00
2014-10-25T21:52:00+00:00
2014-09-16T17:02:10+00:00
95 additional answers
    2013-09-26T05:54:11+00:00
    I figured it out!! Whoot!  You search mouse...go to settings tab, look for customize your mouse and uncheck the tracking....hope this helps someone out there!  Windows 8!
