2013-01-06T19:59:33+00:00
2014-08-26T17:51:47+00:00
There, done.
2013-04-13T14:32:18+00:00
2014-10-25T21:52:00+00:00
2014-09-16T17:02:10+00:00
95 additional answers
    2013-08-08T04:08:52+00:00
    Just bought a Samsung and had this same problem:
    go to Settings>Control Panel>Hardware and Sound>Touchpad
    This should open up plenty of options for you.
    Other laptops are likely different but this should hopefully put you in the right direciton.
