2013-01-06T19:59:33+00:00
2014-08-26T17:51:47+00:00
There, done.
2013-04-13T14:32:18+00:00
2014-10-25T21:52:00+00:00
2014-09-16T17:02:10+00:00
95 additional answers
    2013-07-17T06:19:03+00:00
    Man, I totally agree with you. Hey remember back in the day when windows used to have a feature that would automatically disable the touch pad when another pointing device was plugged into the computer. Man those were the good ole days. Now not only do they not have that, but also the touch pads are usually larger and more in your way. In Windows 9 they are probably going to do away with external mice altogether and we will all be forced to use these stupid trackpads.
