2013-01-06T19:59:33+00:00
2014-08-26T17:51:47+00:00
There, done.
2013-04-13T14:32:18+00:00
2014-10-25T21:52:00+00:00
2014-09-16T17:02:10+00:00
95 additional answers
    2013-04-27T14:34:23+00:00
    On the desktop, in the bottom right corner where the time and date is, I found an ASUS Smart Gesture icon. I double clicked on it and it brung up a check mark window that showed how to work the computer with swiping. I disabled the tap click, of course
    Though I have an ASUS windows 8, it might only work on mine...
