Suspicious AntiVirus Alert Popped Up on Web Page
2013-05-11T03:08:31+00:00
I am suspicious about messages that popped up when I went to a web page I'd never been to before. First a message popped up stating "Microsoft Antivirus has found critical process activity on your PC. You need to clean your computer to prevent system breakage."  And then right afterwards another message appeared -- I might have pressed okay --  in a rectangular box with a thick red stripe across the top that read "Potential Threat Details," and then below "Microsoft Security Essentials detected potential threats that might compromise your privacy or damage your computer. You need to clean your computer immediately to prevent the system crash."  But I noticed that "might" was spelled "mihgt." Then below that it listed the threats as:
Trojan PSW.Win32Launch
HackTool:Win32/Welevate.A
Adward.Win32Fraud
It said each of the three was "critical" and "active" and recommended I "remove" them.
Then below all this was a box I could check that said "clean computer."
Now aside from the misspelling of "might," I do not have Microsoft Security Essentials; I have Windows Defender, so I'm pretty sure this is a fake alert.
And I didn't press "clean computer." But I'm wondering what would have happened if I had; would I have gotten a virus, or a sales pitch to buy more antivirus software? But mostly I want to know what really will happen when my antivirus program -- which, again, is Windows Defender for Windows 8 -- does detect a real virus. It hasn't happened yet so I don't know, and I also would like to be able to distinguish the real alerts from the fake ones, especially if the fake ones do not have misspelled words as a telling sign.
Windows for home | Previous Windows versions | Security and privacy
2013-05-11T09:37:27+00:00
It is a fake alert and creater of that alert can enter as many virus names as he/she can, don't worry about that alert. Just practice safe browsing, do not click on Ads (specially of unknown source), always use original software and download them from their genuine sites only. Run scans from the tools you downloaded, and use free version only (neither Pro nor Trial).
About Trojan in quarantine-
Items in quarantine are neutral and cannot harm your PC, just like criminals in jail. There is no need to delete items in quarantine. You can also run a full scan of your PC to ensure no virus is lurking in your PC.
2013-05-13T15:28:33+00:00
As per your description above, except for the part... "it said it couldn't do much with that"... (Don't know what you mean by this?)
When someone tries to close AdwCleaner after clicking on 'Search' button then AdwCleaner alerts that it has only scanned for Adwares, not removed them and asks to click on 'Delete' button to complete removal. This is what he is trying to say.
71 additional answers
    2016-09-08T22:22:25+00:00
    Hi #1NanaSal,
    It was a good thing that you identified that this was a scam and you were able to alert your bank about this.
    You may also refer this blog, HOW TO: Report the Microsoft phone scam so it will be investigated by the proper authorities as well.
    Regards.
    2016-09-09T00:58:29+00:00
    I get this and a couple others saying I am having a problem and need to call the number.  I press ctrl-alt-delete.  I get task master close the web driver down.  Then use a cleaning software to remove all cookie.  Restart.
