That worked, awesome man, ty.
usb flash drive not a valid backup location for system image
OK, Microsoft continuing to confuse me and others it would seem.
Tried to make system image to USB flash drive in Windows 8 and Yes it would not work. It States " the drive is not a valid backup location ".
Yes its formatted to NTFS. and I have read various sites where it gives instructions how and ive read sites and Microsoft who seem to have conflicting statements.
Please can someone HELP all I want to do is go to windows 7 file recovery in windows 8 - press make system image - select usb drive and sit back.
Windows for home | Other | Recovery and backup
2015-05-14T20:44:28+00:00 -
2015-03-29T16:01:16+00:00 My college-age kid has the same problem. I'm getting him to try ubuntu. How to overcome resistance to change?
2015-02-27T14:54:44+00:00 great so simple if you know,
thanks
2014-05-21T22:46:47+00:00 VNJNJ's solution will save a System image backup to a USB drive. However, if you plan to recover Windows 8.1 (maybe 8.0 too) from a Windows Recovery Drive USB drive it is all for not.
I am using a system with Windows 8.1 installed. Please pay attention to my use of bold as Microsoft has used similar names for a number of items in the recovery space which may lead to confusion if one does not pay close attention while reading.
- Insert both the Windows Recovery Drive USB drive and the USB drive with the System Image Backup.
- Hold the "Shift" key while selecting Power --> Restart to bring up Advanced Boot Options
system shuts down and enters the Advanced Boot Options
- Select "Use a device" --> "EFI USB Device"
system shuts down and enters Advanced Boot Option from the WindowsRecovery DriveUSB drive .
- Select your keyboard layout
- Select "Troubleshoot" --> "Advanced options" --> "System Image Recovery" to bring up "System Recovery Image"
- Select "Windows 8.1" (or 8.0) for Choose a target operating system.
A window will popup saying, "Windows cannot find a system image on this computer"
- click "Cancel"
- Select "Select a system image" and click "Next >"
- click "Advanced…"
- The only options are "Search for a system image on the network"* or "Install a driver"
You can try this yourself as it is non-destrutive if you cancel everything out ("Cancel", "Cancel", "Turn off Computer", remove "Window Recovery drive" (USB key)
*Your wifi driver might not be loaded nor might your wifi password will be entered. I gave up on wifi and used ethernet.
2013-08-28T07:18:03+00:00 the correct line is "createimage" and when entered correct line warnings appeared and stated that creating a custom image can only be used on Refresh not Reset .
Regards
Shivj
