Thanks, I did that and to my dismay, the problem is beyond repair and i have been negotiating with them for a replacement. :(
Lumia 800: Speaker problem, no sound.
I have encountered a problem with my Nokia Lumia 800.
After I turned the speaker volume down to 0 before I went to bed, the speaker stopped working. I noticed this when I overslept for work because the alarm clock on the phone did not give any sound. I thought maby it was intended when the volume was stillt down to 0 (although it would be silly), but I found out when I had turned the volume up and the phone rang, there was no sound.
It turns out the sound does not work no matter what happens, incoming calls, alarms, playing music, etc.
I have tried to restore phone to factory settings, but with little success ...
Has anyone experienced the same problem? Is it a known software issure or sould I consider the phone defective?
2012-06-20T20:37:42+00:00 -
2012-06-18T19:56:09+00:00 Hi Deepakdev,
Thanks for your post. As these forums are user to user platform if you would like to contact Nokia Support please do so through the Nokia Support webpage. You can reach them through mail, phone or chat (where available).
Hope this helps,
Kosh
2012-06-18T19:51:39+00:00 I have same problem with my Nokia 710. Here is what i tried and non of them worked :(
- Removed all software i installed after i bought the phone
- Restored Factory settings
- There is nothing inside the headset jack
- All buttons are working fine
- Diagnostics doesnt show anything
Normal phone calls with earphone and mic works. Surprisingly, headphone and AUX port works. Other than that, No ringtons, no alarms, no radio, no MP3 sound and no video sound. The speaker is just DEAD. I know many people gone thru same problem and no one from the Nokia seems to reply. Nutshell, please dont buy any Nokia Lumia.
2012-05-21T11:33:25+00:00 Indeed.
If you do manage to resolve this issue, you might want to spend a few pounds\dollars on a 3.5mm jack cap. Just a little silicon plug to cover the jack. It's suprisingly vulnerable to getting grit and fluff inside.
I've had to replace the entire jack itself as there was grit caught in the sensor that wasn't going to budge. It's not a huge repair, but don't try to do it yourself unless you really know what you're doing. For the small price of a repair, the parts cost barely £10 so with labour you're not looking at much more than £30-£40 depending on who you visit it's not worth risking your £400 phone!
It would be nice if the jack port itself however came with a cap similar to the charging port. there's no reason for it to be left open as it is. Alternatively, a software update to disable\enable the jack when desired would be a soft fix for this, as the mechanics of the port still work despite the sensor issue.
2012-05-17T12:23:44+00:00 I can confirm that if the phone 'thinks' it has a headset, the audio from the phone is diverted through the headset.
I managed to solve sound disappearing from my phone when I look directly into the headset socket and found something inside it.
It turned out to be a small piece of tissue stuck inside the hole. I managed to dig it out with a small toothpick and the phone speaker is working again.
I remembered now that when the last time I was using it when it was still working fine, my earphone jack didn't want to go into the headset socket and I forced it in. It must have been that a small piece of tissue got logged inside it when I had the phone, the earphone and my tissue all inside my jacket pocket. How it happened, I've no idea.
So, take a look inside the headset socket and see if there's anything inside there which should't be there. I'm so relieved that I was able to 'fix' my phone without resorting to long and expensive repair.
