Error: Power Surge On Hub Port: A USB device has exceeded the power limits of its hub port
2012-07-25T15:53:28+00:00
Original Title:USB DEVICS EXCEEDED THE POWER LIMITS OF ITS HUB....POWER SURGE
THE USB DEVICS HAS EXCEEDED THE POWER LIMITS OF ITS HUB....POWER SURGE....this is what the error message that was displayed everytime i put my pendrive...so i did something ,the error message stopped but cant use any pendrive...
when i put a pendrive,getting notifications at some ports...but explorer not opening the device..:(:(..Please help
2012-07-28T17:36:08+00:00
The error also means that there isn't enought power in the USB port where the device is plugged-in. I would suggest connecting the device to another USB port or use a USB hub that supplies it’s own power.
Check if it helps.
2015-12-09T20:46:52+00:00
Update:
What I had to do was uninstall all USB controllers, restart my computer and then go back to Device Manager and set all my Generic USB ports and USB Root Hub controllers to disallow the computer to turn off the devices to save power by unchecking all four boxes so the message should not appear again. You can complete the latter step by right clicking on all the Generic USB ports and USB Root Hub ports, clicking on properties, clicking on the Power Management tab, and unchecking the box that says "allow this computer to turn off the device to save power". Please note that you will have to uncheck the box for each Generic USB Hub and USB Root Hub port individually to ensure that the message does not return. You may also go to Regedit and follow this path: HKEY_Local_Machine/System/CurrentControlSet/Services/USBCCGP+USBHUB. Under both USBCCGP and USBHUB: Right click and click on New, on the new menu click on DWORD and a New Value field should appear. Now type in this new value field: DisableSelectiveSuspend and hit enter. Finally, click on the newly created DisableSelectiveSuspend field and click Modify; in the Value data box type 1 and press okay. Complete all steps for both USBCCGP and USBHUB.
47 additional answers
    2015-04-12T13:35:18+00:00
    This message comes up when nothing is plugged, what can I do?
    2015-01-22T16:40:28+00:00
    I have not had this issue before, but stumbled on it while trying to remotely help someone else. I seems to me that I would check the power supply. Power supplies can cause some very strange issues if there is not enough power supplying the board and other devices. Anyhow, just a thought.
    2015-01-10T15:04:32+00:00
    My problem is worse !!
    because I get this message while I just installes a PCIe card with 3x usb3 ports ..
    which windows says that it works & In can see it control panel devmgmt.msc
    and I uninstalled everything like suggested but when I restarted I got the same issue
    (that this article is about), while its not an external hub, but a PCIe card ,  !!
    When I connect my USB3 hdd to this card nothing happens, while when I connect it to an existing usb2 port it works fine!! The pciE card is a DE lock 89301 ..
    So who is ultrageeky enough to solve this for me?
