Error: Power Surge On Hub Port: A USB device has exceeded the power limits of its hub port
2012-07-25T15:53:28+00:00
Original Title:USB DEVICS EXCEEDED THE POWER LIMITS OF ITS HUB....POWER SURGE
THE USB DEVICS HAS EXCEEDED THE POWER LIMITS OF ITS HUB....POWER SURGE....this is what the error message that was displayed everytime i put my pendrive...so i did something ,the error message stopped but cant use any pendrive...
when i put a pendrive,getting notifications at some ports...but explorer not opening the device..:(:(..Please help
2012-07-28T17:36:08+00:00
The error also means that there isn't enought power in the USB port where the device is plugged-in. I would suggest connecting the device to another USB port or use a USB hub that supplies it’s own power.
Check if it helps.
2015-12-09T20:46:52+00:00
Update:
What I had to do was uninstall all USB controllers, restart my computer and then go back to Device Manager and set all my Generic USB ports and USB Root Hub controllers to disallow the computer to turn off the devices to save power by unchecking all four boxes so the message should not appear again. You can complete the latter step by right clicking on all the Generic USB ports and USB Root Hub ports, clicking on properties, clicking on the Power Management tab, and unchecking the box that says "allow this computer to turn off the device to save power". Please note that you will have to uncheck the box for each Generic USB Hub and USB Root Hub port individually to ensure that the message does not return. You may also go to Regedit and follow this path: HKEY_Local_Machine/System/CurrentControlSet/Services/USBCCGP+USBHUB. Under both USBCCGP and USBHUB: Right click and click on New, on the new menu click on DWORD and a New Value field should appear. Now type in this new value field: DisableSelectiveSuspend and hit enter. Finally, click on the newly created DisableSelectiveSuspend field and click Modify; in the Value data box type 1 and press okay. Complete all steps for both USBCCGP and USBHUB.
47 additional answers
    2016-02-04T14:48:58+00:00
    I was having the same problem w/ a powered USB hub.  I unplugged the hub, and then plugged it back in.  That seems to have fixed the issue.
    2015-12-09T18:27:44+00:00
    What happens if you turn your computer off, plug the speakers in, and then turn the computer back on? Try turning the speakers on before you turn your computer on.
    The way I solved this problem on my computer was to plug a USB extension cable in the computer, and then plug my device into the cable. I then didn't need to turn the computer on and off. FYI: I am running Windows 7.
    Scott
    2015-12-09T17:15:17+00:00
    No, its not a Windows 10 problem. I reverted back to Windows 8.1 months ago (I had to do a factory reset to get rid of it and until this day it still tries to get me download Windows 10). Any way, this problem started for me last night around midnight. I only have one thing plugged into my USB ports (which is my speakers; computer speakers no longer work) and it keeps saying there is a power surge. I tried bypassing it by going to registry editor and setting USB to bypass the USB surge limit. I tried Method 1 and 2 from the first page, as well: Method 1 did virtually nothing (I tried it three times); Method 2 worked to the point that my speakers are now showing up as a available speaker but the power surge message keeps popping up. I even went in and tried setting my Generic USB ports and USB Root Hub controllers to disallow the computer to turn off the devices to save power by unchecking all four boxes. None of these methods have worked for me. Can someone help?
