Major Mouse problems, Left click acting like right click, very annoying!
2011-01-08T11:42:31+00:00
Hey guys I have a really annoying problem. I have read about it on-line as other people seem to have experienced it but there is no real definitive answer. On rare occasions, my mouse will act funny. When you press the left button, it will act as the right, and the right button will continue to act as the right one. When you go into the mouse settings, even if you swap them around it still acts like there's two right clicks and no left click buttons. I have tried a number of suggestions from elsewhere on the web including re-booting my pc several times, trying to update windows, disabling the mouse, re-installing, using a different mouse etc.. no matter what I do the problem persists.
The only way to get the mouse back to normal is either to turn the pc off and leave it a few hours, in which case sometimes even that does not work. The only other time it rectifies itself is on its own. Sometimes it will just correct itself without you doing anything to it. I will be very thankful for any advice anyone can give. Has anyone else had this problem? Does anyone know anything at all about it? Thanks BTW My system info: Windows 7 Ultimate 64-Bit, Amd Athlon X2 2.2GHz CPU, 4GB Ram, XFX - MI-A78U-8309 M/B, Few SATA drives, Logitech MK300 Wireless K/Board and Mouse.
2011-01-14T23:20:41+00:00
Hi ;
Can you go to start\control panel\system and security\Administrator Tools\Event Viewer
Please check if you have any error message under the Applications
than publish here or go to our website with this error issue to search
Thanks.
59 additional answers
    2011-04-17T03:15:57+00:00
    Device Manager shows two mouse devices: "HID Compliant Mouse" and "PS/2 Compliant Mouse". Which device's driver should I remove?
    2013-05-08T21:40:20+00:00
    I had the same problem! I tried everything and just happened to fix it by myself! Do you happen to have a Dell? If so, go to control panel > mouse > then click on the further left tab on top "dell touchpad" > click on the picture of the touchpad > button settings > change the "middle" clicker to "click" and that should fix it!
    2011-01-12T08:29:43+00:00
    Anyone else got any kind of idea? It's doing it again now. From the moment I turned it on its started doing it (The PC has been off for over 10 hours). Could it be that the Cpu is over heating slighty, hence why the PC still works but some functions are getting messed up, but in my instance only the mouse button's? Unlikely I know but getting a bit desperate now as this seems to be happening more and more often now which is weird as it never happened before and has just randomly started to happen now lol. Thanks for any replies.
    2011-08-06T21:07:03+00:00
    Try stopping KMProcess.exe from the task manager, maybe that works!
