Major Mouse problems, Left click acting like right click, very annoying!
2011-01-08T11:42:31+00:00
Hey guys I have a really annoying problem. I have read about it on-line as other people seem to have experienced it but there is no real definitive answer. On rare occasions, my mouse will act funny. When you press the left button, it will act as the right, and the right button will continue to act as the right one. When you go into the mouse settings, even if you swap them around it still acts like there's two right clicks and no left click buttons. I have tried a number of suggestions from elsewhere on the web including re-booting my pc several times, trying to update windows, disabling the mouse, re-installing, using a different mouse etc.. no matter what I do the problem persists.
The only way to get the mouse back to normal is either to turn the pc off and leave it a few hours, in which case sometimes even that does not work. The only other time it rectifies itself is on its own. Sometimes it will just correct itself without you doing anything to it. I will be very thankful for any advice anyone can give. Has anyone else had this problem? Does anyone know anything at all about it? Thanks BTW My system info: Windows 7 Ultimate 64-Bit, Amd Athlon X2 2.2GHz CPU, 4GB Ram, XFX - MI-A78U-8309 M/B, Few SATA drives, Logitech MK300 Wireless K/Board and Mouse.
2011-01-14T23:20:41+00:00
Hi ;
Can you go to start\control panel\system and security\Administrator Tools\Event Viewer
Please check if you have any error message under the Applications
than publish here or go to our website with this error issue to search
Thanks.
59 additional answers
    2018-05-31T05:05:26+00:00
    answer my question
    2018-05-18T12:48:44+00:00
    I am also facing the same problem. Really it is very annoying. I think i have to leave using mouse in my PC. I have to all the stuff only by using keyboard. Anybody who can help in this.
    2017-12-31T14:45:48+00:00
    I have tried this mouse on three different computers running windows 10.  There are not any errors in event viewer.
