Power/Battery Icon Missing from System Tray Windows 7
2011-03-27T18:46:29+00:00
I have lost my power/battery icon from the system tray.  I've tried a few of the things listed on here but is still seems to be giving me trouble.
Like many others here, it is grayed out and selected to "off".  I'm not sure what to do now.
I have an ASUS laptop with Windows 7 Home Premium.
I happened to notice this at about the same time (thought it might be coincidence) that I removed Kasperskey and added Norton 360.
2011-04-07T23:27:57+00:00
I've had this problem on and off since I had Windows Vista.  It doesn't happen as often now that I have Windows 7.  This is what I do...I open the "Windows Task Manager" by pressing "Ctrl + Alt + Del" or pressing "Shift and Ctrl" keys together then press "Esc".  Click the "Processes" tab and looked for "**explorer.exe".**Select that and click "End Process" at the bottom.  The taskbar and the entire system tray will be gone, but that's okay.  You will go back to the Windows Task Manager.  This time in the "Applications" tab, click on "New Task" button.  Type "explorer.exe".  The Sound and Battery/Power icons will reappear.  Hope this helps.  =)
44 additional answers
    2015-11-26T00:46:04+00:00
    Great fix, worked perfect. Except the only change for Windows 10 is that when you start Task Manager per your instructions, make sure you are on the processes tab, and scroll down to windows explorer, right click and instead of ending the process, just select restart from the right click menu and it will come back automatically, saving the step of having to create the new task.  Thanks so much!
    2015-10-07T01:59:53+00:00
    A huge Thank You.  It worked perfectly!
    2015-05-30T19:58:25+00:00
    Worked perfectly, thanks.  In case of uncertainty, the process in the list is titled "Windows Explorer" (on my computer anyway) which of course is explorer.exe.  That is the process you need to end.
    2015-04-01T15:54:41+00:00
    Fantastic, simple to do and worked first time.
