How do I delete huge files from System Volume Information?
2011-08-16T11:37:52+00:00
I have three large hard disks that I use to store backups of the system.  Some program -- I think it was the defragmenter -- caused Win 7 to place huge files (> 4 GB) in System Volume Information.  Nothing I do wil let me delete these files.  I cannot even take ownership of them.  When I try to take ownership of either the file or of System Volume Information I receive an "Access is denied" error on the file name.  Nothing should prevent an administrator from taking ownership of any file on his system.  How can I delete these huge files?  Please do not answer "Use Disk Cleanup to delete all but the last restore point."  That runs, but it deletes nothing.  On a previous installation of Win 7, I could take ownership of System Volume Information and delete its contents, but ot on this new installation.
2011-08-17T10:05:51+00:00
The System Volume information folder keeps the Restore point entries. Usually it is not recommended to delete the entries from the System volume information.
Step 1 : Stop the Volume shadow copy service.
a:  Go to Start - Run and type Services.msc then press enter.
b: Under the Status column look for any entries that read as "Started", make it as “Stopped”.
**c:**Click apply and then ok.
Step 2 : Then take ownership of the System volume Information folder and then try to delete its contents.
How do I open a file if I get an access denied message?
Hope that helps.
47 additional answers
    2018-02-25T09:26:45+00:00
    Thank you for your help.  Your approach would almost certianly work.  I did a similar repair by taking the disk to another Windows 7 installation and deleting the files there, though I had to circumvent security by taking ownership of the files before the system would let me delete them.  However, the best, most principled solution is the following from Windows 7 built-in help:
    You can manage the disk space that is used by System Restore by following these steps:
    1. Click to open System.
    2. In the left pane, click System protection. If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
    3. Under Protection Settings, click the disk, and then click Configure.
    4. Under Disk Space Usage, move the slider to the right to increase the disk space that system protection can use or move the slider to the left to decrease the disk space.
    I originally set the allowable space to zero, and the system deleted  all the files.  Later I moved it to 10% (of a 3 TB disk).  This is a disk I use solely for backup.  There is no need for restore points.  When I eventually need the space, I will just set the allowable space back to zero.
    Again, thanks for your help.
    Thanks Charles, i rate your answer as the best answer for this particular issue. Because the other suggested methods were either difficult (like using knoppix live CD which might be a completely new thing to an average user) or did not work at all (like taking control of System Volume Information (SVI) folder by stopping the Volume Shadow Copy service by running the services.msc command (in my case it was not running at all!).
    I just want to add this to the very effective and native-to-Window solution suggested by you above :-
    In case the missing space in the disk is occupied by some huge files inside the SVI folder then while sliding the horizontal bar to minimize disk space allocation for restore points, **Windows (i'm using Windows 10) will warn that some exisiting restore points will be deleted***which is quite logical and should be expected. One just needs to proceed ahead to free up the missing space.
    The missing space issue affects external hard disk as well and Charles' solution works with them as well
    By the way, this apparently unexplained missing disk space problem is not limited to internal hard disk of the computer only. In fact, i faced the issue with a 320GB Seagate FreeAgent GoFlex external hard disk. The problem had occurrred after i renamed a 58.5 GB big system image file immediately after creating it with EaseUS Todo Backup app. The name of the big file (almost the size of the system image file of 58.5 GB) residing in the SVI folder consisted of long sequence of digits (and letters?) separated by hyphens. I presume that was the restore point/file created when i renamed the system image file in the disk FreeAgent GoFlex but i'm not sure. The most surprising thing is that the System Restore was not even turned on for this disk! (But then who said everthing is easily explained in the world of computing??!!). I just moved the slider to bring down disk space allocation for System Restore for this particular external disk to 20% from 30% even without turning on the system restore. I just got a warning as said above at *-ed line then i went ahead and the missing space of around 56 GB immediately started showing up!
    2017-09-04T13:48:47+00:00
    i had that same problem
    in my D drive system volume information took space about 43.5 gb i think it was the same reason due to defragmentation of that particular drive (D drive)
    what i did after searching in the google for hours was as follows
    step 1) open control panel
    step 2) open click system and security
    step 3) click on system (or just press windows key + pause in keyboard)
    step 4) click on system protection ( a prompt will appear under which click on  system protection)
    step 5) click on the specific drive in which that problem is
    step 6) click on configure click on delete  a prompt will appear and then click on continue
    then click OK that's it
    problem solved
    if u have followed all the steps correctly then it should work correctly
    i am using windows 8.1 the procedure is same in windows 10
    2012-05-10T10:23:43+00:00
    Thank you for sharing the resolution with us which will help others facing the same problems to fix it.
    2012-05-05T18:24:06+00:00
    I've had a lot of success deleting huge files out of the "system volume information" area using a knoppix live CD.  You restart your system with the live CD in your CD drive, and a knoppix desktop session comes up.  You bring up the file manager, and go look for the "system volume information" area, I think that it was under "OS".  You'll see lots of stuff there that you don't want to delete, and you'll also see some very large files that you can delete one-by-one.  Your system will still boot after this, you'll just have a lot more disk space.  If you're using a smaller SSD as your C: drive, this is very helpful.
    However, if this is the first time that you're doing this, I'd strongly suggest that you are ready to re-install and are fully backed up.  The best way is to have an up-to-date system image ready, that you can just use to restore your system if something goes wrong and/or you accidentally delete the wrong things.
    Good luck, this works well for me.
