How do I finalize a disk (CD-R and DVD+/-R) using Windows ?
2011-03-09T19:35:44+00:00
Hi:
How do I "finalize" a disk (CD-R and DVD+/-R) using Windows ?
I want to finalize the disk...not just close the session/disk.
From what I have read in Windows Help, "closing" allows me to write to the disk later.
Is this true, if the disk is just R, not RW ?
I have burned JPEG images (.jpg files) to CD-R and DVD+R disks.
When I try to play them in my Sony CD/DVD player, it won't recognize the disks.
Sony's user manual says that the disks must be "finalized", not just "closed".
How do I do that with Windows ?
I treid finalizing these disks with Roxio Creator Basic, but it doesn't do anything, except eject the disks.
Windows still says that the disks have free space, and the DVD player can't recognize them.
From what I understand, if the disk is finalized, the will show no free space available.  Is this correct ?
Note:  The disks work correctly on my HP laptop which uses Vista 32-bit Home Premium.  I can view the JPEG images.
Thank you...
DaleB
2011-03-09T19:50:13+00:00
See the link in BOLD below :
Burning a CD
http://windows.microsoft.com/en-US/windows7/help/videos/burn-a-cd
Disc burning: frequently asked questions
http://windows.microsoft.com/en-US/windows7/Disc-burning-frequently-asked-questions
Which CD or DVD format should I use?
http://windows.microsoft.com/en-US/windows7/Which-CD-or-DVD-format-should-I-use
Format a CD or DVD
http://windows.microsoft.com/en-US/windows7/Format-a-CD-or-DVD
Burn a CD or DVD in Windows Explorer
http://windows.microsoft.com/en-US/windows7/Burn-a-CD-or-DVD-in-Windows-Explorer
Burn a CD or DVD in Windows Media Player
http://windows.microsoft.com/en-US/windows7/Burn-a-CD-or-DVD-in-Windows-Media-Player
Burn a CD or DVD in Windows Media Player: frequently asked questions
http://windows.microsoft.com/en-US/windows7/Burn-a-CD-or-DVD-in-Windows-Media-Player-frequently-asked-questions
Change settings for burning a CD or DVD in Windows Media Player
http://windows.microsoft.com/en-US/windows-vista/Change-settings-for-burning-a-CD-or-DVD-in-Windows-Media-Player
Burn a CD or DVD in Windows Media Center
http://windows.microsoft.com/en-US/windows7/Burn-a-CD-or-DVD-in-Windows-Media-Center
Burn a DVD-Video disc with Windows DVD Maker
http://windows.microsoft.com/en-us/windows7/Burn-a-DVD-Video-disc-with-Windows-DVD-Maker
How to Burn DVD's with Windows DVD Maker
http://www.7tutorials.com/how-burn-dvds-windows-dvd-maker
Close or finalize a CD or DVDhttp://windows.microsoft.com/en-US/windows7/Close-or-finalize-a-CD-or-DVD
Excellent Forum for getting help with CD/DVD issues and programs
http://club.myce.com/
Hope this helps.
89 additional answers
    2015-11-02T14:04:51+00:00
    Thank you for this helpful information !!
    2015-11-02T15:22:25+00:00
    It looks helpful, until now it is the first reply what acknowledges there is a difference before "closing session" and "finalize", before trying it I like to get more info about the suggested software.
    Why do Microsoft and Apple do such a fuss about not making burned CDs or DVDs usable in both platforms?  It would make life easier for all  users, as burning them  became such a grey area and it is discouraging users.
    Dolly.
    2015-11-02T17:25:01+00:00
    Dolly.
    Microsoft has a history of initiating policies that trap customers and users onto their platform.
    Whether the company's name is Microsoft or Apple; this in my view, is the only logical reason and or purpose for not distinguishing between closing a disc and finalizing a disc.
    I have in the past used CD burner XP but it kept bugging out after a period of time.
    I am currently using Anyburn which is free and does not install garbage onto your computer. You can download AnyBurn at the following URL.
    http://www.anyburn.com
    2016-05-28T00:55:47+00:00
    Ok, I'm years late to the game, but I may have found the answer to your question. I had the same problem. I could close, but not finalize a disc. Sorry if you have moved on now from Vista, but maybe this is similar in future operating systems?
    The bad news is that for your individual disc that you are trying to finalize, I don't think you can ever do it. When you initially set up to make that disc, you were given a semi-hidden option of how you want to actually write the files to the disc. You unknowingly selected  "Live File System". What you wanted was "Mastered".  So stick in a brand new CD-R and when you get the popup: Prepare this blank disc, click the small bottom left carrot for "Show formatting options". Now you will see the two options (this is where my mind blew up). Select "Mastered".
    Now when you are done selecting files to burn, there is no "close" option, there is only a "burn" option. You don't have to search for it, it's right on the front of the window. When you burn, your disc I think it should be finalized. The reason I say think is that you can actually still re-add songs to this disc, but you have to re-burn it. So it will not show up for me as zero room on the disc.
    So give it a shot and let me know your player now recognizes it as "finalized" or not.
