How do I finalize a disk (CD-R and DVD+/-R) using Windows ?
2011-03-09T19:35:44+00:00
Hi:
How do I "finalize" a disk (CD-R and DVD+/-R) using Windows ?
I want to finalize the disk...not just close the session/disk.
From what I have read in Windows Help, "closing" allows me to write to the disk later.
Is this true, if the disk is just R, not RW ?
I have burned JPEG images (.jpg files) to CD-R and DVD+R disks.
When I try to play them in my Sony CD/DVD player, it won't recognize the disks.
Sony's user manual says that the disks must be "finalized", not just "closed".
How do I do that with Windows ?
I treid finalizing these disks with Roxio Creator Basic, but it doesn't do anything, except eject the disks.
Windows still says that the disks have free space, and the DVD player can't recognize them.
From what I understand, if the disk is finalized, the will show no free space available.  Is this correct ?
Note:  The disks work correctly on my HP laptop which uses Vista 32-bit Home Premium.  I can view the JPEG images.
Thank you...
DaleB
2011-03-09T19:50:13+00:00
See the link in BOLD below :
Burning a CD
http://windows.microsoft.com/en-US/windows7/help/videos/burn-a-cd
Disc burning: frequently asked questions
http://windows.microsoft.com/en-US/windows7/Disc-burning-frequently-asked-questions
Which CD or DVD format should I use?
http://windows.microsoft.com/en-US/windows7/Which-CD-or-DVD-format-should-I-use
Format a CD or DVD
http://windows.microsoft.com/en-US/windows7/Format-a-CD-or-DVD
Burn a CD or DVD in Windows Explorer
http://windows.microsoft.com/en-US/windows7/Burn-a-CD-or-DVD-in-Windows-Explorer
Burn a CD or DVD in Windows Media Player
http://windows.microsoft.com/en-US/windows7/Burn-a-CD-or-DVD-in-Windows-Media-Player
Burn a CD or DVD in Windows Media Player: frequently asked questions
http://windows.microsoft.com/en-US/windows7/Burn-a-CD-or-DVD-in-Windows-Media-Player-frequently-asked-questions
Change settings for burning a CD or DVD in Windows Media Player
http://windows.microsoft.com/en-US/windows-vista/Change-settings-for-burning-a-CD-or-DVD-in-Windows-Media-Player
Burn a CD or DVD in Windows Media Center
http://windows.microsoft.com/en-US/windows7/Burn-a-CD-or-DVD-in-Windows-Media-Center
Burn a DVD-Video disc with Windows DVD Maker
http://windows.microsoft.com/en-us/windows7/Burn-a-DVD-Video-disc-with-Windows-DVD-Maker
How to Burn DVD's with Windows DVD Maker
http://www.7tutorials.com/how-burn-dvds-windows-dvd-maker
Close or finalize a CD or DVDhttp://windows.microsoft.com/en-US/windows7/Close-or-finalize-a-CD-or-DVD
Excellent Forum for getting help with CD/DVD issues and programs
http://club.myce.com/
Hope this helps.
89 additional answers
    2014-06-25T20:10:08+00:00
    As you have read, Explorer does not close a disc or finalize it so you need to do it yourself.
    if you use Ashampoo's Burner program, you have the choice of doing so if you wish.
    It is a simple straight forward program and does anything you want to do with a disc very clearly.
    I have used it for a decade with no issues and have burned every type of disc under every circumstance. I have done videos, rioed, erased and copied. The help is great but I doubt you will need it.
    Good luck.
    Hi:
    It is not Explorer that I am talking about.
    I a referring to Microsoft's Windows DVD Maker.
    I will look into Ashampoo's Burner program.
    I am curious:
    Can Windows DVD Maker be downloaded and installed...by itself...not as part of a suite ?
    Thank you
    DaleB
    2014-08-02T18:49:45+00:00
    Is anybody really listening to Dale Brandt???
    I have the same problem... I cannot FINALIZE a disc.
    This is a very simple and direct.  How does one FINALIZE a disc?
    The questions that you guys ask him are irrelevant!  The question is simple... HOW DO YOU FINALIZE A DISC?
    2014-08-03T01:52:24+00:00
    Your frustration is understandable. There are way to many people who choose to make themselves a fool pretending to give advice when they do not know what they are talking about.
    The answer, nearest I can figure is quite simple, Windows 7 (explorer) does not finalize discs.  The developers were not smart enough to include that functionality. Instead, they choose to lie, as well as try to baffle people with BS rather than admitting the fact that they neglected to include that very important and necessary feature.
    As has been the typical mentality of Microsoft executives and technicians, they prefer to dictate to people what practices are correct even when doing so does not sync with reality and is delusional.
    To get past the problem that a delusional Microsoft has created, you must install a third party disc burner that has the capacity to finalize the discs you burn.
    I know, I could have been nicer but considering that so many answers on this question have been posted by a bunch of intellectually limited individuals, posers, who do not know what finalizing a disc is or means, their cruel lack of integrity just brings out the harshness in me.
    Take care.
    2014-08-03T02:27:59+00:00
    Hi:
    Your comment stated:
    *"The answer, nearest I can figure is quite simple,*Windows 7 (explorer) does not finalize discs."
    To clarify things, I am using Windows Vista 32-bit Home Premium, SP2.
    The program that I have been unable to Finalize DVD-R/RW disks with, is Windows DVD Maker.
    Windows DVD Maker fails to do both, create a Master disk and Finalize a disk.
    The details may be found in my comments on April 28, 2013 (and other dates)
    What I would like to know:
    Can this program be independently be deleted, downloaded from microsoft.com, and re-installed ?
    In other words, uninstalled, downloaded, and re-installed by itself, not part of a software suite.
    I think that it was initially installed as part of a suite called "Windows Live" software.
    DaleB
