How do I finalize a disk (CD-R and DVD+/-R) using Windows ?
2011-03-09T19:35:44+00:00
Hi:
How do I "finalize" a disk (CD-R and DVD+/-R) using Windows ?
I want to finalize the disk...not just close the session/disk.
From what I have read in Windows Help, "closing" allows me to write to the disk later.
Is this true, if the disk is just R, not RW ?
I have burned JPEG images (.jpg files) to CD-R and DVD+R disks.
When I try to play them in my Sony CD/DVD player, it won't recognize the disks.
Sony's user manual says that the disks must be "finalized", not just "closed".
How do I do that with Windows ?
I treid finalizing these disks with Roxio Creator Basic, but it doesn't do anything, except eject the disks.
Windows still says that the disks have free space, and the DVD player can't recognize them.
From what I understand, if the disk is finalized, the will show no free space available.  Is this correct ?
Note:  The disks work correctly on my HP laptop which uses Vista 32-bit Home Premium.  I can view the JPEG images.
Thank you...
DaleB
2011-03-09T19:50:13+00:00
See the link in BOLD below :
Burning a CD
http://windows.microsoft.com/en-US/windows7/help/videos/burn-a-cd
Disc burning: frequently asked questions
http://windows.microsoft.com/en-US/windows7/Disc-burning-frequently-asked-questions
Which CD or DVD format should I use?
http://windows.microsoft.com/en-US/windows7/Which-CD-or-DVD-format-should-I-use
Format a CD or DVD
http://windows.microsoft.com/en-US/windows7/Format-a-CD-or-DVD
Burn a CD or DVD in Windows Explorer
http://windows.microsoft.com/en-US/windows7/Burn-a-CD-or-DVD-in-Windows-Explorer
Burn a CD or DVD in Windows Media Player
http://windows.microsoft.com/en-US/windows7/Burn-a-CD-or-DVD-in-Windows-Media-Player
Burn a CD or DVD in Windows Media Player: frequently asked questions
http://windows.microsoft.com/en-US/windows7/Burn-a-CD-or-DVD-in-Windows-Media-Player-frequently-asked-questions
Change settings for burning a CD or DVD in Windows Media Player
http://windows.microsoft.com/en-US/windows-vista/Change-settings-for-burning-a-CD-or-DVD-in-Windows-Media-Player
Burn a CD or DVD in Windows Media Center
http://windows.microsoft.com/en-US/windows7/Burn-a-CD-or-DVD-in-Windows-Media-Center
Burn a DVD-Video disc with Windows DVD Maker
http://windows.microsoft.com/en-us/windows7/Burn-a-DVD-Video-disc-with-Windows-DVD-Maker
How to Burn DVD's with Windows DVD Maker
http://www.7tutorials.com/how-burn-dvds-windows-dvd-maker
Close or finalize a CD or DVDhttp://windows.microsoft.com/en-US/windows7/Close-or-finalize-a-CD-or-DVD
Excellent Forum for getting help with CD/DVD issues and programs
http://club.myce.com/
Hope this helps.
89 additional answers
    2014-06-07T17:36:31+00:00
    These are for VIsta and Windows 7 :
    Close or Finalize a CD or DVD - see to Close a disc manually
    http://windows.microsoft.com/en-us/windows/search#q=finalize+a+CD
    Rob - SpiritX
    If you would use your brain, you would see that Microsoft is intentionally confusing the two terms. They say close or finalize when they only mean close.
    This is just another attempt from Microsoft to get people accustomed to their way of doing things regardless of whether it works for the individual/company or not.
    The link you insist on pointing to does not tell anyone how to finalize a disc after burning it.  So stop misleading people and wasting their time.
    2014-06-25T16:59:47+00:00
    Hi:
    The link in BOLD did not answer my question.
    It did not tell me how I to "finalize" a CD or DVD.
    Please advise...
    Thank you
    Dale Brandt
    You are correct. That BOLD link does not answer your question. No one will answer your question, because Windows 7 will not finalize an audio CD for you.  Why not? I don't know
    2014-06-25T17:03:59+00:00
    Rob - SpiritX
    that link has nothing to do with finalizing a disc.  Why are there so many answers from folks who seem not to know what finalizing a disc is/means.
    2014-06-25T18:51:38+00:00
    As you have read, Explorer does not close a disc or finalize it so you need to do it yourself.
    if you use Ashampoo's Burner program, you have the choice of doing so if you wish.
    It is a simple straight forward program and does anything you want to do with a disc very clearly.
    I have used it for a decade with no issues and have burned every type of disc under every circumstance. I have done videos, rioed, erased and copied. The help is great but I doubt you will need it.
    Good luck.
