If you do go the virtualization route the reason your having issues is your processor doesnt support VTX (or another name on AMD CPUS, or hardware virtualization) (my guess, it should have thrown up an error box and said this hardware isnt compatible.. and
why)... if your CPU has enough power (and preferably multicored and pref 3gb of ram). you can try a virtualizer that does not require hardware virtualization (Hint.. VirtualBox does not require VTX enabled for all virtualizers, just some)... Try VirtualBox
by Oracle.. its free. and should do the job..VMware Player might also work... Not sure... I know XP mode *INSISTS* on hardware virt (at least the last time i tried it, read somewhere there was a patch but haven't seen it)... but you can import the XP mode
virtualization (the actual file that holds the XP mode virtualization) INTO VMware player...Just some options
(Correction.. there is a new update to XP MOde on MS's download site.... Install the other parts of the XP mode, then you have to run the THIRD file to update it so XP Mode will run without hardware virtualization)
Note the DOUBLE asterisks on the third file link! (Revenge of the asterisks)
(Taken from the Microsoft XP Mode Virtual machine website) (please download from the virtualpc website at http://www.microsoft.com/Windows/virtual-pc/download.aspx and not use
the enclosed links)
Windows XP Mode update
Windows XP Mode
*Windows XP Mode is a 500 Mb file and may take several minutes to download.
**Enables Windows XP Mode for PCs without Hardware Assisted Virtualization Technology. For more information,
visit the Frequently Asked Questions page.
Windows Virtual PC
Realize you now have some options to try...
