Win 7 Sound recorder- audio recording device cannot be found
2009-11-19T03:42:14+00:00
Fresh install (new drive) of Win 7 Hiome Premium 64 bit on Dell XPS 420 Quad Core.  When I launch sound recorder it gives an error that audio recording device cannot be found.  Mic is plugged in front jack.  This worked with Vista.  I enabled show disabled devices and sho disconnected devices.  Any ideas?  I also tried rear mic jack.  I scanned for hardware changes.
2009-12-02T18:19:39+00:00
I did the things you mentioned above:
1.) method 1:  Windows 7 responded that it could not identify the problem
2.) method 2:  checked the show disabled devices and still no devices appear.  It still says no audio devices installed under the recording tab.
3.) method 3:  attempted to update driver and Win 7 reports I have the most up to date driver already
Any ideas?
There is really no other solution than a better driver for the device.
Rating posts helps other usersMark L. Ferguson MS-MVP
48 additional answers
    2012-06-19T11:36:31+00:00
    Thankyou; funny, the simple method is always the best.
    2012-07-12T03:43:33+00:00
    Did this solve the recording internally from a movie disk, cd, or some sound off the internet?
    2012-07-12T04:01:48+00:00
    my solution - uninstall the driver from device manager, check for hardware change, and windows will automatically re-install the drivers, at which time the input device is found. (I've literally tried 5 other ways and none worked...) For reference, I'm on Win7ProSP1.
    every time i uninstall it tell me to restart the computer.
    i restart and i still have sound so i don't think i am uninstalled.
    if i get this to work does it record streaming or just off a plugged in device?
    2012-09-05T00:13:21+00:00
    Hey Hugheser27
    your hint was extremely helpful and  I fixed it thanks! thanks for all of U
