I know this is an old post but I have the Windows 7 answer for this Dell PC issue. It recently happened to me too on my Dell OptiPlex desktop, Windows 7, onboard is SoundMAX Integrated Digital HD audio. I had no "Stereo Mix" type option in the recording
tab. Tried several drivers even back to an XP version. None of the drivers from Dell worked. Until I ran across a posting of others with the same issue and can not record any audio that they can hear coming out of their speakers. It is that the audio drivers
on the Dell site have this feature DISABLED during the drivers installation. To fix this you have to edit the drivers INF file to get the disabled changed to enabled so the recorder will actually install what is needed. Here is what I did with my DELL downloaded
audio drivers install file:
First download the latest DELL audio driver and unpack it, probably at c:\dell\driver\R######
open the folder \ i386 \ Vista \ , it has a file in it called "ADIHdAud.inf" . Open this file with notepad and search for these 2 lines:
HKR,AD1983\Disable, OutR, 1, 01
HKR,AD1983\Disable, MonR, 1, 01
change the 01 into 00 at both lines so it looks like:
HKR,AD1983\Disable, OutR, 1, 00
HKR,AD1983\Disable, MonR, 1, 00
Save the modified
ADIHdAud.inf file.
Now uninstall your sound drivers, reboot pc, go directly back to the folder where you uninstalled the driver (the folder with the R(number)) and
run Setup.exe (it might complain that the files might not be genuine, if so ignore it), reboot after installation and you got Stereo Mix and Mono available. They both work perfect for me. What really blows me away is that if you look at the code in the inf
file is that stereo mix is disabled ON PURPOSE, my question is why???
Also you can go to:
HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Control\Cl ****{4D36E96C-E325-11CE-BFC1-08002BE10318}\0000\AD1983\Disable\
which had the two values: MonR and OutR... both set to "0000 01"
combined with the solution from this page, simply change those values to "0000 00" and restart. Stereo mix and Mono Out are now enabled.
Reinstall any streaming internet audio recording software and they will work now.
