NT Kernel & System using 100% of CPU
2009-04-02T00:19:32+00:00
I just bought a new laptop with Window Vista Basic. The laptop has 3 Gb ram. I was just reading an article on line and then I start to hear the laptop fan running like crazy. then I went to the Resource Monitor and there was an image/program that was using 95% of my cpu and it was my system with description of "NT Kernel & System". It has been going on for over 30mins. Other than restarting the computer, what can I do about this "NT Kernel & System" eating up 95% of my CPU?
2009-07-06T17:17:59+00:00
I've been having the same problem on my HP desktop running Vista home for a couple weeks. I read that someone fixed the same problem by updating some hardware firmware, so I opened Resource Monitor and started unplugging all my hardware one at a time. The instant I unplugged my Belkin USB network adapter, NT Kernel & System dropped down to 0% and my computer unfroze entirely. The same adapter has been causing me a lot of grief for months- it wouldn't respond every time my computer came out of standby. I'll be updating the driver and firmware to see if that helps - otherwise that garbage is going in the trash. I recommend disabling/unplugging hardware (especially if you have any with odd behavior) until the problem stops, then replacing or updating that hardware.
2009-04-02T10:03:09+00:00
Hello Dtsai,
Thank you for posting.  What you just described seems to be some form of mal-ware trying to mascuerade as a legitimate windows service.  Windows does have NT Kernel and also System, but they never show up together as one service, program, or file.
I highly recommend that you use your favorite anti-virus and anti-spyware program and do a full scan of your PC.
Please try the scan and let me know if this helps you
Zack
59 additional answers
    2013-01-05T09:47:09+00:00
    can you speak chinese ?
    我的英文很差劲
    2013-01-05T09:39:10+00:00
    sorry ,i found it no help can you help me ?
    2013-01-05T09:34:58+00:00
    i have the shame problem ,but only when the system was new .the question has't appeard
    can you help me ? 我在中国
