When using my microphone, the microphone level automatically adjusts.
2009-11-14T15:52:58+00:00
In order to fix it temporarily I have to right click the speaker icon in the tray, go to recording devices, double click my mic, go to the levels tab and readjust it. It becomes a huge problem when talking with the mic and the level goes from 100 down to 20 randomly and all of a sudden I can't be heard.
Sometimes it goes down right away, and I don't see a checkbox to disable this automatic adjustment.
I have unchecked allowing applications to take exclusive control but I'm not sure this is actually related.
2010-10-24T12:30:47+00:00
This has also had no affect on the problem.   Again I knew this would not help.   You see,  the above suggestion merely stops communications software adjusting the volume of other software items.
This problem is not related to the output volume of software being auto-adjusted.   It is to do with theinput level (sensitivity) of the microphone being auto-adjusted.
To try and clarify where the problem lies,  the input level that you see when you right click speaker icon,  select 'Recording Devices',  click the 'Recording' tab,  select the 'Microphone' and click 'Properties',  then click on the 'Levels' tab.   It is the 'Microphone' level there that is auto-adjusting.
Please note that this problem is related to the Microphone Input level.  Not a volume output level.
2010-10-30T12:05:40+00:00
Hi gerri,
To further clarify, are you saying that the volume slider in the microphone properties (pictured below) is auto-adjusting:
If yes, do you see the slider moving on it's on?
If yes, this is not a function of Windows 7 that I am aware of.
I suggest uninstalling Skype temporarily and restarting the computer to see if the issue resolves.
Chris
61 additional answers
    2011-12-14T01:44:51+00:00
    It's a function of some program you're using. For instance, I was using a telephony program called VCC agent from five9.com. It had a setting called "automatic gain control." I turned that off, and problem solved. If messenger/skype/whatever doesn't let you turn that off, get a new program. It's not a windows 7 feature.
    2011-12-07T15:12:40+00:00
    Finally found something on the google talk forums:
    finally finallyfound a solution.  hope this can help someone else until logitech fixes the issue.
    it requires editing the windows registry, which involves changing settings in a sensitive area of the system.  if you're not familiar/comfortable with that, seek further help before following this advice.
    to turn off google talk plugin's audio auto-adjustment:
    close your web browser and webcam software.
    open regedit, navigate to
    HKEY_CURRENT_USER\Software\
    this seems to require a reboot, so don't get discouraged if it doesn't work right away.  I also found that going into the google talk settings and changing the echo correction changes the flag value to 3 and the problem comes back.
    Now I'm wondering if there's a similar key for skype, et. al
    2011-12-07T14:59:27+00:00
    This doesn't work.
