When using my microphone, the microphone level automatically adjusts.
2009-11-14T15:52:58+00:00
In order to fix it temporarily I have to right click the speaker icon in the tray, go to recording devices, double click my mic, go to the levels tab and readjust it. It becomes a huge problem when talking with the mic and the level goes from 100 down to 20 randomly and all of a sudden I can't be heard.
Sometimes it goes down right away, and I don't see a checkbox to disable this automatic adjustment.
I have unchecked allowing applications to take exclusive control but I'm not sure this is actually related.
2010-10-24T12:30:47+00:00
This has also had no affect on the problem.   Again I knew this would not help.   You see,  the above suggestion merely stops communications software adjusting the volume of other software items.
This problem is not related to the output volume of software being auto-adjusted.   It is to do with theinput level (sensitivity) of the microphone being auto-adjusted.
To try and clarify where the problem lies,  the input level that you see when you right click speaker icon,  select 'Recording Devices',  click the 'Recording' tab,  select the 'Microphone' and click 'Properties',  then click on the 'Levels' tab.   It is the 'Microphone' level there that is auto-adjusting.
Please note that this problem is related to the Microphone Input level.  Not a volume output level.
2010-10-30T12:05:40+00:00
Hi gerri,
To further clarify, are you saying that the volume slider in the microphone properties (pictured below) is auto-adjusting:
If yes, do you see the slider moving on it's on?
If yes, this is not a function of Windows 7 that I am aware of.
I suggest uninstalling Skype temporarily and restarting the computer to see if the issue resolves.
Chris
61 additional answers
    2011-02-06T06:45:39+00:00
    Yes, the problem IS with Windows Messager. And, you.
    You have SET your Mike up............to WORK in the OS, BUT!
    You have NOT set it up.......................in Messager, even SKYPE, itself.
    How to do that, IS,.................TOOLS, in Messager/Skype. Then, the AUDIO/VIDEO Settings options.
    Now, MAKE the necessary adjustments there!
    You have NOT done this, which is 'WHY' there is a CONFLICTING  automatic Mike Level ALWAYS occurring!
    2011-02-06T03:37:45+00:00
    No, i think his problem, like mine is with Windows Messenger specifically.
    Under the video and sound set-up in WINDOWS MESSENGER specifically, there is a microphone slider. Even when this is set, messenger is prone to reducing it massivly (Sliding it to the left) mid call, or at the start of a call.
    2010-11-05T19:24:45+00:00
    I am having that problem as well and have also tried the communications tab. I dont have Skype installed on my computer. I only use Windows Live Messenger for voice chat.
