In Windows 7, I can't get pictures to show as thumbnail previews. I've tried three different methods suggested on this site. Why is this so difficult?__
The three methods I've tried are as follows:
1. Open the folder in Windows Explorer and click the
down arrow next to Views at the top. Choose
Medium icons and see if the thumbnails start working again.
2. If not, click on Organize, then
Folder and Search Options. Click the View tab. Make sure that "Always show icons, never thumbnails"
does not have a check mark next to it.
3. Open Control Panel. (Classic View). Click on the System icon. Click on the advanced system settings link. Under Performance, click on the Settings button. In the Visual Effects tab, Check "Show thumbnails
instead of icons.”
I am facing the same issue in Windows 8 Basic, Home (or call it whatever), but I do not seem to solve the problem. I went to the Explorer settings and made sure of that the option "Display file icon on thumbnails" and applied to all folders but it came out
with no results could be mentioned.
I also went to the "Computer Properties> Advanced System Settings > Performance" and I let the system choose what's best for computer. Show thumbnails instead of icons was checked though but the problem is still there.
There is no way to go to "gpedit.msc" since my Windows edition does not support this feature.
I hope someone feeds me back with a solution to fix this issue cuz it's irritating me.
Your response is anticipated and appreciated in advance. :)
