Pictures do not display as thumbnail preview
2010-02-03T09:23:47+00:00
In Windows 7, I can't get pictures to show as thumbnail previews. I've tried three different methods suggested on this site. Why is this so difficult?__
The three methods I've tried are as follows:
1.    Open the folder in Windows Explorer and click the down arrow next to Views at the top.  Choose Medium icons and see if the thumbnails start working again.
2.    If not, click on Organize, then Folder and Search Options.  Click the View tab.  Make sure that "Always show icons, never thumbnails" does not have a check mark next to it.
3.    Open Control Panel. (Classic View). Click on the System icon. Click on the advanced system settings link. Under Performance, click on the Settings button. In the Visual Effects tab, Check "Show thumbnails instead of icons.”
2010-08-16T19:59:31+00:00
Not sure where these answers were going but to simply make your pictures show in thumbnail mode in win7 simply open your pictures folder, click tools, folder options, view, then uncheck "Always show icons, never thumbnails"
Don't forget to hit apply!
That should do it.
2010-10-30T14:32:38+00:00
Click on the Start button, go to Control Panel.  In Control Panel select System.  From the System window select Advanced system settings.  Select Performance settings.  Be sure the box Show thumbnails instead of icons is checked.
2010-02-04T05:02:06+00:00
Hi RRWilcox,
You may try the following steps and check whether you can get thumbnail previews.
  1. Open the Pictures library by clicking the Start button, and then clicking Pictures.
  2. In the left pane, click the folder that contains the pictures you want to view.
  3. Click the arrow next to the Views button, and then move the slider to change the size of the thumbnails.
For more information, you may refer the following link:
http://windows.microsoft.com/en-US/windows7/View-and-print-picture-thumbnails
You may also try to Enable or disable the thumbnail preview using group policy editor.
Note: The following steps won’t work in home editions of Windows 7.
To do this, follow the steps:
  1. Click on start and type gpedit.msc in start search bar and press enter.
  2. Now navigate to User Configuration, Administrative Templates, and Start Menu and Taskbar in left pan of Group Policy Editor
  3. Locate “Turn off Taskbar Thumbnails” in right pan of Group policy editor and double click on it.
  4. Select Enable or Disable click apply and Press ok
  5. Now check your Taskbar, it shouldn’t show Thumbnails Preview.
Please Note: Taskbar Thumbnail Preview only works when you have Enabled Aero in Windows 7.
Praseetha. K.
326 additional answers
    2011-09-29T21:51:26+00:00
    Aha! I think I finally understand the problem. You referred to the default photo editor. Click. All this time I’ve been referring to some clipart. But clipart that was located in “My Pictures.” On my old computer I had reorganized some Office clipart into custom folders. For example, rather than using their subject tags I had put them into folders by Style number. When transferring files from the old computer to the new, I just dragged those folders into “My Pictures.” No wonder I could only see them in a “paint preview” window! I hadn’t reorganized them in the new “Clip Organizer!” What a relief. This has been plaguing me for months. Thanks for your response. (Now if I could only make Clip Organizer “Edit Keywords” work. Sigh.)
    2011-09-29T22:16:18+00:00
    It happens,
    The integration of the windows 7 libraries has been a rough road from even vista not to mention x-p :)
    This new (my pictures...) is pretty much a joke anyway,
    I'm not familiar with the clip organizer or what version of windows you had it in, unfortunately,
    But most of what wl photo gallery uses is descriptive tags and people tags,
    If you right click a photo file and select properties and go to the details tab section,
    Is any of the clip information listed and in what fields.
