Hi RRWilcox,
You may try the following steps and check whether you can get thumbnail previews.
- Open the Pictures library by clicking the Start button, and then clicking
Pictures.
- In the left pane, click the folder that contains the pictures you want to view.
- Click the arrow next to the Views button, and then move the slider to change the size of the thumbnails.
For more information, you may refer the following link:
http://windows.microsoft.com/en-US/windows7/View-and-print-picture-thumbnails
You may also try to Enable or disable the thumbnail preview using group policy editor.
Note: The following steps won’t work in
home editions of Windows 7.
To do this, follow the steps:
- Click on start and type gpedit.msc in start search bar and press
enter.
- Now navigate to User Configuration, Administrative Templates, and
Start Menu and Taskbar in left pan of Group Policy Editor
- Locate “Turn off Taskbar Thumbnails” in right pan of Group policy editor and double click on it.
- Select Enable or Disable click apply and Press
ok
- Now check your Taskbar, it shouldn’t show Thumbnails Preview.
Please Note: Taskbar Thumbnail Preview only works when you have Enabled Aero in Windows 7.
Praseetha. K.
This guide was very helpful, I found the things to change, although not in the Start Menu and Taskbar, but in the All Settings. I checked, as you mentioned, but nothing happened. I tried the simple way, (changing the size at the Pictures folder), and I tried
everything, that here on this page as answer stood. In my pc doesn't exist any Tools in the Pictures folder. Everything that there is, I chose and tried, but those did not work. What else can I do?? Please help me......
